Old 09-06-2009, 05:41 AM   #1
aafxsniper
aafxsniper is on a distinguished road
Default SL Sedan Auto Trans problem..????
I have a 2001 Sl Sedan. This may be normal but am not sure. My car seems to shift too soon at times, and not at others..?? When I'm driving along it's fine, but if I'm on the highway for instance, I come to a hill, it doesn't want to downshift unless I put it almost to the floor. If I pass a car in passing gear, when it upshifts it seems to miss 3rd and go right into o/d. There is no clunking or banging or hardshifts. It's just a strange thing that maybe I'm not used to. It does rev high if I'm driving hard. Shifts from 1st to 2nd at around 4500 rpm and so on, otherwise it's normal. Just mainly the hill thing whilst on highway. Any ideas? Or am I paranoid...lol
Add to aafxsniper's Reputation
Rate the quality of this post and help aafxsniper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aafxsniper is offline   Reply With Quote
Old 09-06-2009, 11:32 AM   #2
groingo
groingo is on a distinguished road
Default Re: SL Sedan Auto Trans problem..????
I also have one that does the same thing and strangley enough my mothers Olds Alero does the same thing.
Best thing you can do without pulling your hair out is to just shift it manually.
When a Saturn auto trany works good it is nice but when they act up they are a major pain in the you know what, best solution I have found is avoid the automatics all together and stick with a manual which has none of the problem causing electronics and will last longer, cost less in the long run and get you improved mileage as well.
94 Saturn SW1 (Cash for Clunkers Reject....no kidding)
96 SL2 (Rescued)
Add to groingo's Reputation
Rate the quality of this post and help groingo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
groingo is offline   Reply With Quote
Auto trans problem sensible S-Series General 0 03-24-2008 10:33 AM
Auto trans problem or ecm or pcm problem? HELP! nitronick S-Series Tech 6 03-02-2007 09:51 PM
Auto trans problem.. again Av8r S-Series Tech 12 05-28-2005 03:46 PM
auto trans problem plumsl2 S-Series Tech 4 03-12-2004 12:33 AM
auto trans problem -93 rwatkins Miscellaneous Tech 4 09-22-2003 07:51 PM
