Old 08-28-2009, 03:45 PM   #1
markmacallister
markmacallister is on a distinguished road
Default "Not-Ready" Inspection Rejection
I have seen posts on this throughout the forums, but being a newbie here I'd like to provide my details in hopes someone can point me quickly in the right direction. I have a 1998 SW2, 221K miles, runs like a clock. My mechanic told me today that it will not pass inspection in North Carolina due to a "not-ready" rejection.
The report he gave me summarizes the monitors:
Misfire - Ready
Catalyst - Not Ready
Secondary Air System - Not Available
O2 Sensor Heater - Ready
Fuel System - Ready
Heated Catalyst - Not Available
A/C System - Not Available
EGR System - Not Ready
Comprehensive Component - Ready
Evaporative System - Not Ready
O2 Sensor - Not Ready
Other - Not Available
From what I've seen on this forum, there are commonly inspection problems related to the coolant temperature sensor, the thermostat and/or the amount of fuel in the tank. I would also note that I had the crank position sensor replaced in March 2009 and a full tune-up in February 2009.
Any suggestions? I would love to get by simply replacing the coolant sensor and/or the thermostat, but that seems too easy. And did I mention that I'd rather be strangled than take my car to a dealer? I have been with the same mechanic for 13 years and don't wish to go elsewhere...
Thanks so much.
Add to markmacallister's Reputation
Rate the quality of this post and help markmacallister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
markmacallister is offline   Reply With Quote
Old 08-28-2009, 03:57 PM   #2
bprimerano
bprimerano is on a distinguished road
Default Re: "Not-Ready" Inspection Rejection
'not ready' doesn't mean there is a problem, it means the computer was cleared and you have not had enough drive cycles yet for it to make a determination for those systems. Did you disconnect the battery recently?
Add to bprimerano's Reputation
Rate the quality of this post and help bprimerano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bprimerano is offline   Reply With Quote
Old 08-28-2009, 04:17 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
See post #8:
http://www.saturnfans.com/forums/sho...d.php?t=115959
See post #2:
http://www.saturnfans.com/forums/sho...d.php?t=128998
See post #2:
http://www.saturnfans.com/forums/sho...d.php?t=136826
Post #2 agian:
http://www.saturnfans.com/forums/sho...d.php?t=124469
You got the idea.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 08-28-2009, 06:01 PM   #4
DonP
As Low Satrun says above, you gotta run it to do the full driving cycle so the ECM can run the full bag of diagnostics.
As to the ECTS, it may or may not be an issue. You should make sure you have a good, new type with a good connector in any case.
Add to DonP's Reputation
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 05:11 PM
XM "Ready" Radio in 2007 Vue UncleBooty Vue Tech 50 04-10-2008 10:10 AM
1999 SL OBD II "Not Ready" failed NYS inspection HELP! suessaturn S-Series Tech 21 03-21-2007 09:14 AM
"Owner Appreciation" Vehicle Inspection kevin2002 S-Series General 9 10-29-2005 11:49 AM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
