Old 08-07-2009, 10:32 PM   #1
sr20fd3st
sr20fd3st is on a distinguished road
Default Could cranking with wrong valve timing bend valves?
Hi. I just replaced the valve stem seals in the head of my 99 SW2.
The damn chain must have moved quite a bit and after i bolted the cams and sprockets back up it wouldnt start. then i realized they were way off so I fixed it. still wouldnt start so cranked the motor once over I retimed the cams at the next TDC (cylinder 1), thinking maybe it was sparking and fueling at the exhaust stroke TDC instead of compression stroke TDC.
When I went to put the sprockets back on the cams and bolt everything up the second time, I noticed that there was a good 1/4 inch gap between the rockers and the cam lobe base circles on the intake side. Only thing I can think of is that ALL the intake valves are not up all the way. Cranking sounds too easy like no compression. (fast as hell). No Start.
So by that my best guess is the valved got smashed for being all the way down at TDC and are too bent to even go halfway back up the valve guide. Before I pull the head, I wanted to make sure this all made sense.
Makes sense that exhaust valves are okay, since they are supposed to be open at TDC on the exhaust stroke.
Thanks,
Oliver
Add to sr20fd3st's Reputation
Rate the quality of this post and help sr20fd3st reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sr20fd3st is offline   Reply With Quote
Old 08-07-2009, 10:36 PM   #2
Default Re: Could cranking with wrong valve timing bend valves?
Yes, it usually does bend a few.
Old 08-07-2009, 10:36 PM   #3
Phyzik sl2
Phyzik sl2 is on a distinguished road
only if they struck the piston head
Add to Phyzik sl2's Reputation
Rate the quality of this post and help Phyzik sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phyzik sl2 is offline   Reply With Quote
Old 08-07-2009, 10:40 PM   #4
sr20fd3st
I just cant think of any other reason why the valve rockers would be so far from the cam lobes, other than that the stems are bend are just cant make it up the sleeves.
Old 08-07-2009, 11:33 PM   #5
If you have clearance between the back of the cam and the cam follower then they are bent.
does broken timing chain damage valves? schreckman S-Series Tech 8 05-12-2009 10:30 AM
Timing and Valves Bullrider626 S-Series Tech 5 07-18-2007 02:46 PM
Tapping Valves or Timing Chain or ?!?!?!?!? cfg83 S-Series Tech 16 03-04-2007 01:49 PM
stalling problem after replacing timing chain, valves ls1racer ws6 S-Series General 4 02-19-2006 05:50 PM
Timing chain/ valves mozart3851 S-Series Tech 10 08-18-2005 11:21 PM
