Old 07-14-2009, 12:51 PM   #1
C130Flyboy
C130Flyboy is on a distinguished road
Dizzy Replaced Auto Trans will not go into 4th gear
My 98 SL2 had reverse slam and a leak started. Had the Trans replaced a few months ago and the car stopped going into 4th (stuck in 3rd and has High RMP) with the SES light on. I had the Codes checked and this is what I get.
I've got some code(s) associated with the SES light.
OEM Number to Cross: P0741
Is this an easy fix?
Add to C130Flyboy's Reputation
Rate the quality of this post and help C130Flyboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
C130Flyboy is offline   Reply With Quote
Old 08-28-2009, 04:37 PM   #2
s-petersen
s-petersen is a jewel in the roughs-petersen is a jewel in the roughs-petersen is a jewel in the rough
2002 SL1
Default Re: Replaced Auto Trans will not go into 4th gear
No torque converter clutch.simple/cheap things,tcc fuse, bad connection on top of trans, bad actuator,bad temp sensor(generates a po713 or 714 code)
After that I'm not sure.
1994 SL2 with 220,000, 1994 SC2 with 128,000 Both had reverse slam,SL2,fixed with nuts,SC2 needed valve body-sold,2002 SL1 251,000 needed cat, 1998 Ford Ranger 160,000 1994 SC2 166,000 parts
Add to s-petersen's Reputation
Rate the quality of this post and help s-petersen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s-petersen is offline   Reply With Quote
auto sl2 no 4th gear help marijuandroid S-Series Tech 4 09-16-2009 05:41 PM
98SL2 with replacement AUTO Trans will not go into 4th gear C130Flyboy S-Series Tech 3 08-28-2009 04:25 PM
trans valve body replaced-no 4th gear! saturnrookie S-Series Tech 11 01-23-2008 02:34 PM
Replaced auto trans valve body, now no 4th Moonhole S-Series General 3 12-29-2007 09:25 AM
93sc2 trans not shifting into 4th gear joe's95sc1 S-Series Tech 1 09-15-2005 12:00 AM
