Old 07-09-2009, 12:41 PM   #1
LaphLaw
LaphLaw is on a distinguished road
Default Replacing the radiator -- how?
So I discovered several weeks back that I was leaking coolant. I traced the leak to the radiator (there's a crack in it), and now I need to replace it. Calling a few distributors, the price for a new radiator runs about $100-150. Labor is about another $50-100. So I'm thinking about doing it myself. That said...
1) What tools do I need to get the job done?
2) Are there any "gotchas" (i.e. it takes forever to get x part off, and isn't worth the time)
3) Anything I should know up front before doing the job myself?
My car:
'99 Saturn SL1
Thanks!
Add to LaphLaw's Reputation
Rate the quality of this post and help LaphLaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LaphLaw is offline   Reply With Quote
Old 07-09-2009, 12:57 PM   #2
David Grigor
David Grigor is on a distinguished road
1995 SW2
Default Re: Replacing the radiator -- how?
Plenty of info on how to replace in the DIY section. Just search.
Add to David Grigor's Reputation
Rate the quality of this post and help David Grigor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David Grigor is offline   Reply With Quote
Old 07-09-2009, 12:59 PM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
Replacing is not too difficult. I've done it a few times in my Saturns. The main issue is a crack on the Driver's Side top of the radiator.
A quick question to you is: Is your car auto or manual?
If auto; it would be good to get the replacement trans cooler lines. These are a dealer only part and will run you about $15-$20/piece. You will need to replace these at the upper and lower points on the new radiator. If you have a manual...DO NOT remove the tabs that are located where these hose connections are, otherwise you will have leaks.
To replace the radiator you will need to do the following:
*Lift car up via jackstands (ramps preferred)
*Remove the Coolant Tank Reservoir Cap, and Drain Coolant via drainstop on bottom of radiator.
*You will need:
A Large Pair of Vice Grips, 10MM Socket wrench. 13MM Socket Wrench, Phillps Head Screwdriver, Flat Head Screwdriver
*After draining the coolant, remove the air filter tubing and housing in front of the battery (13MM Bolts)
*Now that the coolant is drained, you will need to remove the Upper Radiator Hose with the Vice Grips
*Remove the Coolant Fan and the O2 Sensor.
*Remove the 10MM Bolts that hold the Radiator to the Condensor. Be aware that the Condensor needs to be secured so that it doesn't fall out of the bottom of the car. On the Passenger side of the Radiator, there is a little "Lip" on the radiator that the Coolant Fan sits in that you will need to angle to get the Coolant Fan out.
*There are 3 (10MM) bolts that you need to remove to get the radiator out and another 2 (10 MM) that are at the top inside that you need to remove.
*Once you have these out, install the new radiator and reinstall everything. Run Distilled water through the system and refill with Universal Yellow Coolant. Check for leaks. Refill through the coolant tank until the level is topped off and the coolant tank doesn't flash anymore.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 07-09-2009, 01:40 PM   #4
GQROD
GQROD is on a distinguished road
1997 SW2
If you order one online, make sure you open the box in front of the delivery person ( fed ex, ups ) and check to make sure it is not warped.
Very important to do this since the box will look new but you have to take the radiator out of the box and check it. If it's warped do not accept it send it back and get another one.
Definetly order the trans oil cooler lines and be careful not to break the plastic clips that hold the lines to the tranny otherwise you have to buy the new plastic clips and metal hex connectors.
Watch richpins video it's great for the first timer to get a sense of what is involved.
Make sure you cover the 02 sensor connector with a plastic baggy to make sure you don't get coolant or tranny oil on it and ruin the 02 sensor.
Follow the advice given by oldnuc in your search and you will be fine he helped me a lot !!!
I just replaced mine http://www.saturnfans.com/forums/sho...d.php?t=140551 , this is the thread done just over a week ago.
Add to GQROD's Reputation
Rate the quality of this post and help GQROD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GQROD is offline   Reply With Quote
Old 07-09-2009, 04:29 PM   #5
BarnOwl
BarnOwl's Avatar
Radiators aren't a precision item. A little bowing won't hurt anything. I get cheapies from rockauto for around $80. They're mostly straight but, not perfect. I've yet to replace a transmission line. Take the quick disconnects loose at the transmission and pull the lines with the radiator. You'll be able to get the lines loose without boogering them up. If you have to, use a pair of vice grips to reinforce your flare wrench to get them off.
Add to BarnOwl's Reputation
Old 07-09-2009, 04:31 PM   #6
sr20fd3st
sr20fd3st is on a distinguished road
I remember it being straight forward. hoses off, mounts off, radiator out. Install in reverse.
Add to sr20fd3st's Reputation
Rate the quality of this post and help sr20fd3st reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sr20fd3st is offline   Reply With Quote
Old 07-10-2009, 11:56 AM   #7
10mm socket on ratchet, vice grips or pliers for the hose clamps, something to drain antifreze into and ~30 minutes.
I'll probably end up doing it again on mine as I used a radiator I pulled from a parts car but hey, it's cheaper and faster then buying one online, then waiting for it to come in.
Old 07-10-2009, 04:25 PM   #8
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
When my rad finally blew. I went to the local Upullit. Searched and found a 'new' one. I figured it would last longer since it was relatively new. It last about 2 weeks. I went back and got another 'new' one . It lasted about a month. It turns out these newer rads I got from the JY were the 'made in China' junk. When I went back the third time, I pick out a factory rad that was 10 yrs old. And it is still leak free. I can change that rad in my sleep now. ;-)
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 07-10-2009, 04:37 PM   #9
MikeNW
MikeNW's Avatar
1997 SL
Pretty straightforward.
I think I took out the headlight(s) to reach bolts easier.
Air conditioning condenser is sorta klutzy though but it's not a hard job.
08 Burgman 400
Add to MikeNW's Reputation
Old 07-10-2009, 04:38 PM   #10
MikeNW
MikeNW's Avatar
1997 SL
Oh yeah, in my photos, I cut out the access hole (in the air dam) so it's easier to turn the radiator stopcock.
08 Burgman 400
Old 07-10-2009, 06:26 PM   #11
GQROD
1997 SW2
So that's why mine is missing!!!!! i couldn't figure out who would pull this off when i bought the car, now that makes sense.lol
Old 07-10-2009, 11:09 PM   #12
2NDSOUT
2NDSOUT's Avatar
1999 SL
Not knocking you...but you created more work for yourself. The headlights don't even need to be touched.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 07-11-2009, 09:45 AM   #13
Carlr33
Carlr33 is on a distinguished road
My car:
'99 Saturn SL1
Thanks!
Largest gotcha is getting a new radiator that works, see link:
http://www.saturnfans.com/forums/sho...t=2nd+radiator
206,000 MILES
Add to Carlr33's Reputation
Rate the quality of this post and help Carlr33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carlr33 is offline   Reply With Quote
Old 07-11-2009, 09:59 AM   #14
MikeNW
MikeNW's Avatar
1997 SL
"The headlights don't even need to be touched"
There are two 10mm bolts (socket size) that connect the A/C condenser to the radiator, lower front of radiator. It just seemed easier to remove the headlights to get at them.
Removing headlights is a 5 minute job. Only 2 bolts each. Plus I am in no particular hurry.
08 Burgman 400
Replacing cracked radiator bender S-Series Tech 9 08-06-2008 09:33 AM
replacing radiator wavejunkie S-Series Tech 12 11-10-2007 10:09 AM
replacing radiator - what else should I do? WorkWagon S-Series General 8 08-28-2005 10:42 AM
Replacing Radiator Hose(s) Terry57 S-Series Tech 11 08-23-2004 10:01 AM
Replacing the Radiator MSGJVH S-Series Tech 8 06-27-2002 11:34 PM
