Old 02-03-2009, 11:37 AM   #1
RBrown20
RBrown20 is on a distinguished road
RBrown20's Avatar
1994 SL
Default HELP HELP HELP!!!! NO TAIL LIGHTS OR DASH LIGHTS..... PROBATION IN three HOURS!!!
Allright, so my car got hit my a drunk driver, busted pass. side tail light. this was sunday morning, saturday night, whatever. so im driving home last night, my dash starts flickering, and then they go out. all dash lights, and my tail and brake lights. I still have reverse lights and my left blinker... first assumption, wires on busted tail light rubbed and blew a fuse. i couldnt find the fuse last night, I checked 3 of them, cant recall which ones, i think prk lghts, drl lghts and body? I cant remember, but I have to leave in 2.5 hours to go to probation. can I get another fuse to check? or somthing.. i need brake lights and tail lights... im driving through BUSY BUSY down town.
94 SL
Where the fug is my mirror?
~No Regrets, Just Life Lessons~
I need more speakers
94, SL, 250k+, manual trans, no power anything, sparkplugs, exhaust, CAI, steering wheel, FLUX CAPACITER!!!!
RBrown20 is offline   Reply With Quote
Old 02-03-2009, 11:39 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: HELP HELP HELP!!!! NO TAIL LIGHTS OR DASH LIGHTS..... PROBATION IN three HOURS!!!
Check all of your fuses, check your relays and check your wires. Probably just got a little moisture on them... you're such a sissy! If you have a tester, pull it out and make sure you do not have a cut wire or something or a wire grounding the others out.
Saturnless...
Old 02-03-2009, 11:42 AM   #3
RBrown20
RBrown20's Avatar
1994 SL
I could figure it out, but I have to report to my probation officer in a few hours, I need some tips to hurry. do you know what fuse my brake and tail lights are on?
Old 02-03-2009, 11:57 AM   #4
OnDaGround
OnDaGround's Avatar
1993 SC2
not off the top of my head. It only takes max 3 minutes to pull every fuse... come on now...
Saturnless...
Old 02-03-2009, 12:49 PM   #5
Check your owner's manual. IIRC, stop and tail/park lamps are on two different fuses. Taillamp fuse is probably marked PARK.
Did you check BOTH fuse boxes?
Before actually replacing the blown fuse(s), I'd bet a nickel that the light socket itself is shorting either/both circuits to ground. Go back there and trace the wire "upstream" from the bulb socket. About a foot upstream, there should be a connector; unplug that connector so as to remove that short harness from the circuit. Later, you'll have to see what's wrong with it; it could be something as simple as a bashed-up bulb base creating a short. Worst-case, you'll have to replace that little harness with one from a salvage yard car.
Old 02-03-2009, 12:54 PM   #6
RBrown20
RBrown20's Avatar
1994 SL
Thank you sir... the bulb shorting the socket is what im going for, I have tail lights, but no brake lights now.. ****.
Old 02-03-2009, 01:44 PM   #7
paterson
paterson is on a distinguished road
1998 SL1
Quad driver ,,,,,,,,,
paterson is offline   Reply With Quote
Old 02-03-2009, 01:49 PM   #8
Betcha 90% of drivers have no idea what hand signals are... it's actually sunny and warm (30?) today
Old 02-04-2009, 10:57 AM   #9
RBrown20
RBrown20's Avatar
1994 SL
DID YOU SEE THE SNOW!!!! WTF?!?! oh, and I grew up on motorcycles, I know hand signals. but it sure as hell isnt 30* today. the only problem is, ya, I know hand signals, but not the guy behind me.
Old 02-04-2009, 10:59 AM   #10
OnDaGround
OnDaGround's Avatar
1993 SC2
good point... lol. Well did you go? And have you figured out what the hell your problem is... oh I mean the car's problem is.
Saturnless...
Old 02-04-2009, 12:38 PM   #11
RBrown20
RBrown20's Avatar
1994 SL
ya, I went, its all good. bulb shorting out, but still no brake lights... any one got any more ideas, i cant find a bad fuse.
Old 02-04-2009, 01:22 PM   #12
My bad, we live in different parts of the state
...and the cops, who love to hand out "fix it" tickets... you don't want to be late to meet with a PO because you got pulled over
Anyway, find the truck that backed into your car and her PPI will pay for your repairs
Old 02-04-2009, 01:47 PM   #13
Stop looking for "a bad" fuse, and look for THE fuse for the brake lights, as documented in your owner's manual, and indicated on the covers for the junction boxes. TEST that fuse with an ohmmeter / continuity tester.
Next, test for power at the fuse socket, and at both sides of the brake light switch, both with and without activating it.
Old 02-04-2009, 04:50 PM   #14
RBrown20
RBrown20's Avatar
1994 SL
would that be the owners manual that didnt come with the car. and the covers that do not tell me which one? and I will use the multimeter in my storage unit. yes, if one of these scenerio's played out the way I wanted them to, I wouldnt need to post this thread. I apologize if this is rude, I am a little stressed out.
Old 02-04-2009, 05:04 PM   #15
No, that would be the one, well, any one of the 70-ish, available on eBay right now. (Well, it would actually be the one of many that were available on eBay back when you bought the car, _before_ you needed it, but I digress....)
Old 02-04-2009, 05:04 PM   #16
OnDaGround
OnDaGround's Avatar
1993 SC2
did you check for the wires for nics or any cuts in them... Did you check the connectors for corrosion. I had a taillight that burned out on me every day... changed the bulb holder out because you could see where it was burned never had the issue again....
I broke my rule. I try to, and you should too, not try to relate your car to the OPs as not all problems are the same, even with same symptoms... but sometimes it helps.
Saturnless...
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 04:33 PM
No dash lights, or tail lights? MrSL2 S-Series General 4 01-04-2010 11:31 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 03:08 PM
dash lights and tail lights out Vijay SC2 Ion General 3 08-19-2008 02:38 PM
2001 L300 Tail and dash lights ONLY come on when i hit the brakes. kennethgill L-Series Tech 11 04-17-2008 01:06 AM
