Old 12-30-2008, 11:43 AM   #1
Jayconf
Jayconf is on a distinguished road
2007 VUE 2.2L
Default grunt or groan when start off
Hi guys,
I recently (around 20K miles) noticed a grunt or groan noise from the front of the vehicle when I accelerate the car after idling for a while.
Saturn technician told me it is ABS self check and it is normal. I came back and did some internet research and found that the abs self check does do such noise, at least sometimes for some cars.
My question,
1) Why I never noticed it before? I have had the cars for 1.5 years and only noticed it after one year. It means it did not do that during the first year, otherwise I won't miss it. Is there any part worn out so that the noise becomes noticeable? Should I replace such parts?
2) will the situation become worse overtime?
Thanks.
Jay
Add to Jayconf's Reputation
Rate the quality of this post and help Jayconf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jayconf is offline   Reply With Quote
Old 12-30-2008, 01:56 PM   #2
aquatechie
aquatechie is on a distinguished road
Default Re: grunt or groan when start off
Thanks.
Jay
Like you, I didn't notice the ABS self test until owning the vehicle for some time. It kicks in the moment I go past 5mph after turning the engine on. You'll notice it more if you *gently* coast or accelerate on smooth pavement. On the other extreme, you may not notice it at all if you take off on gravel or poorly paved surfaces. The problem doesn't appear to to have gotten worse in my VUE. I believe my VUE has always done it, but I just wasn't paying any attention to it most of the time. I don't think it'll get worse over time.
Add to aquatechie's Reputation
Rate the quality of this post and help aquatechie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aquatechie is offline   Reply With Quote
Old 12-30-2008, 02:59 PM   #3
burnout
burnout's Avatar
I only noticed it on mine after I disabled it, if that makes sense. I pulled the ABS fuse because I wanted to have a little fun in the snow. The ABS light would come on after I started moving, because the self-check couldn't perform.
Once I installed the fuse, the *bzzzt* became obvious to me again once rolling! I doubt there's anything wrong with your car.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-30-2008, 03:06 PM   #4
Jayconf
2007 VUE 2.2L
sounds like I just have to ignore and live with it..
Old 01-01-2009, 01:41 PM   #5
silversurfer13
silversurfer13 will become famous soon enough
silversurfer13's Avatar
u should be good..i notice mine because my cb radio picks up the noise..right when u take off just over like 5 mph..
Add to silversurfer13's Reputation
Rate the quality of this post and help silversurfer13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silversurfer13 is offline   Reply With Quote
Steering Column Groan. baskerj S-Series Tech 7 04-06-2004 08:50 PM
Nasty groan from P/S at almost full lock auxmike Miscellaneous Tech 3 03-29-2003 08:41 AM
Groan in the steering 94sc293sl1 S-Series Tech 11 02-23-2003 09:55 PM
Vue steering groan DMK's Vue Vue General 6 06-18-2002 02:18 PM
New Grunt Whelan S-Series Mods 7 11-11-2001 01:07 PM
