Old 11-11-2008, 10:50 PM   #1
RyboCollier
RyboCollier is on a distinguished road
Default 1998 Saturn SL1 Idle Issues
Hello all,
I'm sure this has been a thread that has been posted quite a few times as this seems to be an issue with a lot of Saturn owners. I'm having difficulty finding out what the problem is with my car. When I start my car it idles fine, but when I start driving(sometimes without even shifting gears) the car will idle at 1500-2000k. The problem does fix itself sometimes but it always seems to rear its ugly head again. Now, I have replaced two parts on my car. My memory is kind of bad but I know I have replaced the IAC Valve, and the ECTS? I'm not to sure about the 2nd one, but both from what I've been told can cause the car to idle iregularly. Now, im being hopeful and thinking that the IAC valve that I replaced may be faulty and a solution to this problem would be a quick replacement of the part. Im wanting to know if there is anything else that I should look out for? The throttle body has been cleaned as well as I understand that could cause problems too. Im open for any insight to this problem, thanks!
Add to RyboCollier's Reputation
Rate the quality of this post and help RyboCollier reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RyboCollier is offline   Reply With Quote
Old 11-11-2008, 11:03 PM   #2
Default Re: 1998 Saturn SL1 Idle Issues
The engine coolant temperature sensor wouldn't allow the engine to be erratic if its been replaced and the connector checked for corrosion. This may be a throttle position sensor issue; one hint is if the engine idles high and the engine is shut off immediately with a re-start with a normal idle, the tps is worn and needs to be replaced.
To be sure about whether the coolant sensor was replaced or not (it is a must) go to the bottom of this page and use the Forum Jump to look in the How-to library for the pictures of the old one next to the replacement brass one.
The iacv is reliable enough not to be any concern.
Old 11-12-2008, 07:47 PM   #3
RyboCollier
Thanks for your reply, I appreciate it. I forgot to mention that when I got the IAC replaced the car ran perfectly for about 4 weeks, then the problem came back..
Old 11-12-2008, 07:49 PM   #4
RyboCollier
Oh, and I confirmed with your help I have had the ECTS Coolant Temp Sensor replaced.
Old 11-12-2008, 08:26 PM   #5
RyboCollier
Well, I've purchased a TPS and I will be installing it tomorrow. Gotta love this forum I didnt know how to replace the TPS but I found that awesome video tutorial on how to do it.
Thanks guys! Lets hope this fixes the problem!
Old 11-12-2008, 10:25 PM   #6
justinkennedy
justinkennedy is on a distinguished road
justinkennedy's Avatar
2000 SC1
2005 ION-2 Sedan
I had the same problem a little while ago. TPS fixed it and along with a new PCV valve my car runs like new. Hope to hear from you when you put the TPS in.
Add to justinkennedy's Reputation
Rate the quality of this post and help justinkennedy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justinkennedy is offline   Reply With Quote
Old 11-16-2008, 04:34 PM   #7
RyboCollier
Well, i'm happy to report that the TPS has seemed to fix the problem for now, lets hope it stays that way. Thanks a lot guys!
94 SL1 Idle issues Bagbyboy S-Series Tech 10 11-18-2009 12:32 PM
2002 SL1 idle issues. mike2002 S-Series Tech 3 06-23-2009 02:46 PM
1998 Saturn Sl1 (Rough Idle)(OBD2 codes 200-300) WadeNKC S-Series Tech 5 04-30-2009 12:56 PM
1998 SL1 Transmission Issues KingRex S-Series Tech 1 03-26-2009 05:48 PM
1998 SL1: Idle issues and flashing lights miss_smase S-Series Tech 2 06-11-2007 01:50 PM
