Old 10-02-2008, 12:12 PM   #1
chevy57
chevy57 is on a distinguished road
Default 99 SL2 service light on, but no stored codes
Guys,
I just bought a 99 SL2 as a winter car. It runs great, but has a service engine light problem. When you first start the car the light does not come on, but after a few minutes it comes on. I shut it off and turn the key on to scan the computer no codes stored. I tried disconnecting the scan tool, starting the motor and wait for the light to come on then plug in the scanner, but it still can't find the error code. What should I try next?
chevy57
Add to chevy57's Reputation
Rate the quality of this post and help chevy57 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chevy57 is offline   Reply With Quote
Old 10-02-2008, 12:16 PM   #2
Default Re: 99 SL2 service light on, but no stored codes
you are using a code reader, not a scanner. The parts store is not going to do you any good either. This is not the cheapest approach but it works. Pull the PCM-B fuse and leave it out for several minutes. Put it back and drive to the dealer of your choice and get then to pull all of the codes. Write them down and come back here.
The service light is usually one of the Quad drivers. Actually, with the 99 they are the only thing that turns it on. It can be a driver failure but as it takes a while to come on I doubt it. The first step is to get the codes. Guessing will not work here. And it does not sound like a bad bulb from your description either. A bad bulb will turn on the Service light. make sure that they all come on when you first turn the key to run.
Old 10-02-2008, 12:37 PM   #3
This is the SES light, and NOT the "Wrench" light?
Add to madpogue's Reputation
Old 10-02-2008, 12:45 PM   #4
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
I was going to ask the same question.
Which light is it in the picture below.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SES light no codes stored cooling temp sender? chevy57 S-Series General 3 10-20-2008 02:49 PM
Service Engine Soon light on, no codes lroyse Vue Tech 8 07-28-2007 09:08 AM
service light on, no stored codes, no cruise control cernest Vue Tech 2 11-25-2006 11:33 AM
Service light is on throwing 2 codes mudnsoccerguy S-Series Tech 3 02-23-2006 01:40 PM
Service light on but no codes LenZelinski S-Series General 12 11-01-2004 10:16 PM
