Old 03-26-2008, 01:23 PM   #1
Dang
Dang is on a distinguished road
Dang's Avatar
2000 SL2
Default L-series motor mounts?
Hey all,
I'm in the S-series side of Saturn a lot more often, so just ignore anything stupid i might say
I encouraged a friend to get a 2000 LS1 (around 75K right now) a couple of months ago, and he loves it. But recently, the car has been vibrating at idle. Instinct tells me it's his motor mounts, kinda like the TAM on my SL2. I looked under the hood, and i believe there are two, one on the right side and one on the left. A quick look on saturnparts.net showed that yes, there are right/left motor mounts. I searched and searched, but I couldn't find any info, like if they're a common problem or directions on how to change them.
Any help is greatly appreciated!
Thanks
Add to Dang's Reputation
Rate the quality of this post and help Dang reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dang is offline   Reply With Quote
Old 03-26-2008, 01:33 PM   #2
sstar
sstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nice
sstar's Avatar
2002 L-Series 2.2L Wagon
Default Re: L-series motor mounts?
Originally Posted by Dang View Post
Hey all,
Thanks
I don't know any technical details about the motor mounts. However, my mechanic said they were definitely a weak spot on the L Series. (among other things)
Add to sstar's Reputation
Rate the quality of this post and help sstar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sstar is offline   Reply With Quote
Old 03-26-2008, 02:40 PM   #3
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
slide under the front of the car and look for the mount that sits next to the radiator fan and starter. I had mine break and that'll cause a lot of crap to go wrong.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 03-26-2008, 11:42 PM   #4
fred2003
fred2003 is on a distinguished road
fred2003's Avatar
2003 L-Series 3.0L Wagon
Are the V-6 mounts built any stronger ?
The more I know, the less I remember.................
Add to fred2003's Reputation
Rate the quality of this post and help fred2003 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fred2003 is offline   Reply With Quote
Old 03-27-2008, 10:31 AM   #5
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
V-6 mounts are not a problem. Haven't heard of anyone who's broken one or worn one out.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 03-27-2008, 12:05 PM   #6
Dang
Dang's Avatar
2000 SL2
Sweeeet, thanks rob.
anybody know any hints (or anything I definitely should not do) to changing one? Is it one of those "if you can change your oil then you can do this" things?
Thanks again for the replies!
Dan
Old 03-27-2008, 09:45 PM   #7
Robman
Robman's Avatar
so was it an engine mount? easy test. open your hood and have someone watch your engine from the side of the car. apply park brake and put your foot on the brake pedal. put the car in D and tap the throttle while still holding the brake. check for excessive engine movement. then try the car in R and check again. excessive movement as in you see the engine twisting inside the engine bay is due to a faulty engine mount.
Rob
2001 Turbo L200
1997 F150 XLT
Do It Yourself
Old 03-28-2008, 01:18 AM   #8
Dang
Dang's Avatar
2000 SL2
AWESOME! thanks again, robman. I appreciate it mucho.
I guess it's almost common sense, but it's still a good idea. I'll check it tomorrow and inform you of the results.
Dan
Motor Mounts DHOOP S-Series Tech 3 11-20-2005 04:43 PM
Motor mounts cegusman S-Series General 7 11-15-2005 02:55 PM
Motor Mounts Vita Mods and Performance 4 11-28-2004 11:12 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
Motor mounts for L-series Qlara L-Series Tech 4 05-31-2002 07:16 PM
