Old 12-22-2007, 06:31 PM   #1
Dave19yz
Dave19yz is on a distinguished road
Default Fog lights to stay on when high beams are on
Hey guys, new to the forum so hello to all. I already did a search, so I apologize if i missed somethin obvious, but i came up with nothing.
Here's the situation:
I bought a '96 Sc2 last february as a daily driver, after a little work, it runs great. However, when I bought it, there was no radio. So I bought one at wal mart and rewired it. Unfortunately, I could not find the switched and constant 12v power sources (and i checked every friggin wire in there with my voltmeter), so I used an add-a-fuse circuit for the switched 12v, and a splice tap from one of the fog light wires as the consant 12v. It's worked great for the past few months...they only problem is, when i turn the hi beams on...my radio turns off...
I don't do that much driving at night normally, but now with daylight savings time over, I drive home at night in the dark...and would like to listen to the radio!! So, how do I get the fog lights to stay on when the brights are on. Is it as simpe as jumping the pins on the fog light relay?
Sorry for the long post, any help is appreciated.
Add to Dave19yz's Reputation
Rate the quality of this post and help Dave19yz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dave19yz is offline   Reply With Quote
Old 12-22-2007, 06:38 PM   #2
MikeH
MikeH is on a distinguished road
MikeH's Avatar
2000 SC2
Default Re: Fog lights to stay on when high beams are on
The fog lights are supposed to be off while high beams are on.
The radio needs to be wired correctly!
MikeH
Add to MikeH's Reputation
Rate the quality of this post and help MikeH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeH is offline   Reply With Quote
Old 12-22-2007, 06:41 PM   #3
Dave19yz
I understand that, however there is a way to have the fog lights not turn off when the high beams are on.
And the radio is wired correctly, i am just using a different switched 12v and constant 12v source.
-Dave
2006 GTO Impulse Blue on Blue, 18s, M6, Corsa, Kooks, and HPtuners
1996 SC2 - Auto, 32mpg, 187k and running strong
Old 12-22-2007, 07:12 PM   #4
Sky King
Sky King's Avatar
The cigarette lighter is always hot. You can get power there.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-24-2007, 07:12 PM   #5
Dave19yz
That's a good thought, but i often use the cig lighter for accessories (i.e. my xm, phone charger, and even for my computer out on job sites), i dont wanna draw too much and continually blow fuses. Any other ideas?
-Dave
Old 12-24-2007, 09:57 PM   #6
S3aturnR
S3aturnR's Avatar
1999 SL1
...let's see... either figure out a way to jimmy the fog lights or wire your stereo to a proper power supply??? tough call.
i'd say wire the stereo correctly (if it turns off with the hi-beams on, it's not wired correctly). if you can't figure it out on your own, perhaps you could enlist the assistance of your nearest local radio shop?
there really is no need for shoddy work or elaborate work-arounds...
s3aturnr
Add to S3aturnR's Reputation
Old 12-24-2007, 10:15 PM   #7
Dave19yz
s3aturnr
I understand it's not "technically" wired correctly, as obviously it wouldn't be wired up to the fog lights, however I checked and rechecked every wire in the dash (all the wires were loose since whoever owned the car before me literally just ripped their stereo out) and there was no constant 12v source. It's not such a pain that I would take it to a local radio shop and get bent over to get it wired "correctly".
I suppose I can just add a circuit to a constant source off the fuse panel, I'll check them all tomorrow.
Every car I've ever owned has had a way to bypass the high beam on/fog light off conundrum, hell it just required snipping a pin off the relay on the goat.
-Dave
Old 12-25-2007, 01:13 AM   #8
MikeH
MikeH's Avatar
2000 SC2
The Haynes manual shows an Orange wire as being hot at all times. It has a 5 amp fuse noted "chime". Maybe your chime fuse is bad?
The yellow wire for the radio is hot in acc or run and is fused at 10 amps.
If you want your fog lamps to be on with the high beam, post that question for someone in the "Mods" forum. Maybe someone that knows does not read this forum.
MikeH
Old 12-25-2007, 02:24 AM   #9
SaturnManiac
SaturnManiac's Avatar
If you can't wire it correctly for whatever reason, then find another source that would be hot, like a spot where something would be for an option that you don't have installed.
As for getting to fog lights to stay on while the high beams are on, I don't really know how to do that, as a matter of fact, I don't even have fog lights, don't really need them here. But having your brights on when using fog lights is almost pointless, since when there is fog brights just make seeing worse...I've been through enough fog to know that, LOL.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-25-2007, 12:55 PM   #10
Dave19yz
Interesting, I'll have to check that fuse. The switched 12v that i used has an inline 10A fuse, as does the constant 12v which is currently drawn off the fog lights...thanks for your help guys.
-Dave
Old 12-26-2007, 01:55 AM   #11
It sounds like the previous owner didn't just remove the radio, but hacked off the radio connector. Eek. As said, the RADIO fuse provides ACC-switched power and the CHIME fuse provides constant power. Problem is, a lot of aftermarket radios are sorta bass-ackwards in their design. The OEM radio draws the majority of its power from the RADIO fuse, and only a trickle for the memory from the CHIME fuse. But a lot of aftermarket radios draw the majority of their power from the wire that needs to be on constantly (for memory), and use the ACC-switched power only as a "trigger". So people hook up fairly powerful radios exactly by the book, and blow the CHIME fuse.
As for keeping the fogs on with the high beams, you need constant power (or at least power that's on with the parking lights) to the pink "B" terminal on the switch. And you need to decommission the existing pink wire feed from the high beams. I posted some crude instructions here: http://www.saturnfans.com/forums/sho...37#post1048237 ; still haven't gotten the gumption to post a separate thread that'd be worthy of moving to How-To.
Add to madpogue's Reputation
Old 12-26-2007, 06:45 PM   #12
Dave19yz
Mike H...thank you that's exactly what i needed. The chime fuse was blown, replaced it, and voila, 13.1V on the orange wire at all times...wired it up and the radio works perfect...and doesn't turn off when i throw on the high beams. who'd a thunk the "chime" fuse was also the constant hot for the radio!
-Dave
Old 12-26-2007, 06:46 PM   #13
Dave19yz
Thanks man, if I hadn't been able to get the constant hot, i def would've used your instructions.
-Dave
Fog lights AND Hi beams? jflecours Astra Tech 26 12-20-2009 09:43 AM
Fog lights go off when High beams are on afk123 Astra General 18 05-12-2009 10:02 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
fog lights only stay lit if I hold the switch down mongo_man S-Series Tech 6 06-30-2008 11:42 PM
Replacing Daytime Running Lights/High Beams... RustyJCNC Mods and Performance 8 08-28-2002 06:55 PM
