Old 08-03-2007, 09:55 AM   #1
red87tll
red87tll is on a distinguished road
Default 97 sc2 throwing codes
1997 sc2 twin cam, 260k.
throwing codes:
p0141 o2 sensor heater circuit malf.
p0452 Evap emissions control sys. press. sensor low.
I have replaced that gas cap and the rear o2 sensor. its still throwing codes.
any other clues? would a bad fuel filter cause the evap code?
thanks
--James
Add to red87tll's Reputation
Rate the quality of this post and help red87tll reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
red87tll is offline   Reply With Quote
Old 08-03-2007, 09:32 PM   #2
Default Re: 97 sc2 throwing codes
For the HO2S have you checked all of the fuses? Specifically the EGR fuse. Have you checked to see if you are getting key on power to the HO2S? Should be on the pink wire. Ground on the black/white wire?
P0452 could be the sensor on the fuel tank or bad wiring. This code should not be able to be set by a leaking evap system.
Add to ssicarman's Reputation
Saturn throwing codes HELP!! bambibuster89 S-Series Tech 4 02-28-2009 01:03 AM
1999 SL1 throwing codes P0301, P0405, P0507 justinchristie S-Series Tech 2 06-05-2008 05:54 AM
New ECTS, now throwing codes at me!! Tempsho S-Series Tech 27 03-02-2006 07:02 PM
Service light is on throwing 2 codes mudnsoccerguy S-Series Tech 3 02-23-2006 01:40 PM
Throwing codes 23 35 45 JS593 S-Series General 9 01-05-2006 12:11 AM
