Old 07-25-2007, 05:19 PM   #1
lroyse
lroyse is on a distinguished road
Default Service Engine Soon light on, no codes
I'm new to Saturns, but not new to car repair so this one has me a little stumped. I am out of town with friends in their 2003 Vue, 4 cylinder stick. The check engine light came on this morning, and since we're out of town, and I don't have my code reader with me, we stopped by the parts store to have them check it. "Passed - No Codes". I thought they must have had a bad reader, so we went to a second parts store. "Passed - No Codes". What causes this?
Add to lroyse's Reputation
Rate the quality of this post and help lroyse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lroyse is offline   Reply With Quote
Old 07-26-2007, 02:00 PM   #2
dlighthill
dlighthill is on a distinguished road
Default Re: Service Engine Soon light on, no codes
I had this happen to me last year. It went off after a few days and then the next week my battery died.
Add to dlighthill's Reputation
Rate the quality of this post and help dlighthill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dlighthill is offline   Reply With Quote
Old 07-26-2007, 02:24 PM   #3
bandit77
bandit77 is on a distinguished road
bandit77's Avatar
my 05 did this a year or so ago while travelling through indiana. i filled up just over the border from ohio, and i think that the higher ethanol content of the gas sold in indiana threw the ecm for a loop. after running that gas through and refilling in missouri the light went out. i had it scanned at the local saturn dealer i work at when i got home and no codes were stored...weird, but it hasn't happened since.
Freakin' Awesome!!
Add to bandit77's Reputation
Rate the quality of this post and help bandit77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bandit77 is offline   Reply With Quote
Old 07-26-2007, 06:45 PM   #4
lroyse
Thanks folks, I appreciate any help I can get.
The light came on about halfway through a tank of gas, so I guess that could be it. A little too late for it to be a gas cap thing. But even the gas cap sets a code in the ecm/pcm. I was really under the impression that when the SES or CE light came on, the computer had turned it on for a reason, and there was a code stored. This thing has no codes, and the light is on solid. The codes have not been cleared, because there were none. I guess I'll try disconnecting the battery to see if that will reset it.
Old 07-26-2007, 07:29 PM   #5
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Don't clear the code until you know what it is. If it's not an OBDII generic code, many scanners will not pick it up. Did the scanners they used have vehicle and manufacturer specific setups or did they just go with generic? If you're going to diagnose the problem, you don't want the code to clear. Also, clearing the code erases your freeze frame data, which can also be very helpful in diagnosing a fault.
Old 07-26-2007, 09:06 PM   #6
lroyse
It was a generic OBDII key-on-engine-off test scanner. I'm not sure if Saturns have a key-on-engine-running type test like some other vehichles, but there scanners wouldn't do that type of test on any vehichle.
There seems to be no degredation in performance, no rough idle, no symptoms at all except this light is on. Even fuel economy appears to be the same. It just baffles me. It is about a thousand mile over due for an oil change, (4000 on this oil and filter) is it possible that's the cause? If so, would it show on a KOEO test? Car has 72k miles on it, and has been fairly well maintained.
Might I suggest a scratching-head icon? LOL
Old 07-26-2007, 11:05 PM   #7
Evap system may not run tests until the fuel level is low enough so it may just be a loose/improperly sealed gas cap. Usually the tests don't run until the fuel level is under 85%.
Add to ssicarman's Reputation
Old 07-28-2007, 12:59 AM   #8
lroyse
Well, the light has decided to go out. I haven't done anything. Not even refilling it with gas. So, as long as the light doesn't come back (which I assume it will) I'll never know what caused it to come on to begin with.
Thanks again for all your help. If I do figure it out, I'll be sure and post the answer.
Old 07-28-2007, 09:08 AM   #9
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
It should probably be checked just the same. Depending on what state you live in, it won't pass inspection if there's a code of any kind stored in its little pea brain.
Add to kodak_jack's Reputation
Rate the quality of this post and help kodak_jack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kodak_jack is offline   Reply With Quote
"Service Engine Soon" Light on..read codes? tap50 S-Series General 10 09-04-2009 02:00 PM
Service Engine Light On, No codes found? SheckyZ28 Vue Tech 4 03-21-2007 12:16 PM
Service light is on throwing 2 codes mudnsoccerguy S-Series Tech 3 02-23-2006 01:40 PM
Service light on but no codes LenZelinski S-Series General 12 11-01-2004 10:16 PM
Service engine soon light setting irrelevant codes help ferdypooh Miscellaneous Tech 9 06-28-2002 09:21 AM
