Old 06-04-2007, 11:43 AM   #1
BWSEAHAWK
BWSEAHAWK is on a distinguished road
Default Key turns but clicks or hums wont start
I have SL2 2002 intermittingly I go out to start car and the key turns but clicks or hums but won't start. Other times it just starts right up. what any tips as to what the problem is? Thought it might be an ignition cyl lock problem not sure any help will be appreciated.
Add to BWSEAHAWK's Reputation
Rate the quality of this post and help BWSEAHAWK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BWSEAHAWK is offline   Reply With Quote
Old 06-04-2007, 11:47 AM   #2
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Key turns but clicks or hums wont start
Make sure there is no corrosion on the battery terminals, and that they are tight.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-04-2007, 11:53 AM   #3
BWSEAHAWK
Default Re: Key turns but clicks or hums wont start
I cleaned battery post and made sure all was connected properly. The problem continued.
Old 06-04-2007, 12:05 PM   #4
Is the click/hum coming from inside the car, or under the hood?
Add to madpogue's Reputation
Old 06-04-2007, 12:07 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Is it a stick or automatic?
If a stick, make sure the floor mat isn't bunched up under the pedals, you have a clutch interlock.
If an automatic, try starting in neutral instead of park.
I suspect the hum is the normal noise of the in-tank fuel pump, you do not normally hear it because the car has started and will drown out that noise.
Add to eljefino's Reputation
Old 06-04-2007, 12:24 PM   #6
BWSEAHAWK
the humming and clicking are coming from inside the car. The car is automatic and have tried starting in neutral but that hasn't worked either.
Old 06-04-2007, 12:45 PM   #7
KawaiiBoricua
KawaiiBoricua is on a distinguished road
KawaiiBoricua's Avatar
1993 SC2
sounds like a dead battery, get it charged, or get a new one. But also check ur alternator. Because it may not be giving out the proper voltage to charge ur battery while ur driving. Im pretty sure that should help u
Add to KawaiiBoricua's Reputation
Rate the quality of this post and help KawaiiBoricua reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KawaiiBoricua is offline   Reply With Quote
Old 06-04-2007, 01:43 PM   #8
To elaborate on elj's idea, do you hear the hum when you turn the key to START, or to RUN?
Old 06-05-2007, 12:57 AM   #9
BWSEAHAWK
The humming is when you turn the key to start all other things work lights radio heater a/c just the ignition turns but won't start
Old 06-07-2007, 01:02 AM   #10
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
I have the same problem. Sometimes if you hold the key in start for like a minute it randomly just starts right up. And it does it most when it's been sitting in the sun for a while. I feel that my starter might be nearing the end of its life..
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 06-07-2007, 02:28 AM   #11
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Sounds like a dying starter to me....
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-07-2007, 03:04 AM   #12
Red Sc2
Red Sc2 is on a distinguished road
Red Sc2's Avatar
Same Problem here... It IS your starter! Change it!
Add to Red Sc2's Reputation
Rate the quality of this post and help Red Sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red Sc2 is offline   Reply With Quote
Old 06-07-2007, 03:38 AM   #13
oseberg
oseberg is on a distinguished road
Make sure it's your starter. Take an extra wire and connect it to your solenoid and run it up to your battery, then put electrical tape on the end. The next time this happens, pop the hood, remove the tape, then connect the wire to the positive battery terminal and see if the engine turns over. If it does, go try the key again, and if the problem persists, it's definatly something other than the starter. If it doesn't turn over, then the starter is definatly bad.
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
Old 06-07-2007, 12:48 PM   #14
dcp
dcp is on a distinguished road
dcp's Avatar
Check to make sure connections at starter are clean and tight.No corrision
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 06-07-2007, 12:54 PM   #15
Bigdaddy94sc2
2006 ION-2 Sedan
Or you can just get under the car and see if there is voltage on the purple wire to the starter. If you have voltage there, with no starter movement, the starter is bad. That is as long as your pos batt cable is good.
1995 sl1 turns over but wont start daboys88 S-Series Tech 1 04-02-2009 02:20 PM
1999 Saturn SL turns over but wont' start dabatman99 S-Series Tech 14 11-14-2008 07:35 PM
95 SL2 turns over, wont start has spark/fuel honda hater SL2 S-Series Tech 20 05-30-2008 07:32 PM
Engine turns over but wont start! mad@mysaturn S-Series Tech 4 03-29-2008 12:44 PM
2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) mymimi75 L-Series Tech 1 08-18-2006 11:50 AM
