Old 06-03-2007, 12:30 AM   #1
filteritout
filteritout is on a distinguished road
Default Engine Jumps at high RPM
I just purchased a 2002 L200 with 111K miles at an auction. When I am driving the car and it gets up to 50-65 MPH the front end starts to shake. I figured it was a motor mount. Further inspection showed that all was ok them, but when I rev the engine to a higher idle it cuts in and out and causes the engine to jump, thus the same reason it shakes while driving soen the road at higher RPMs. I assume that it is some sensor or something. Any ideas?
Thanks
Add to filteritout's Reputation
Rate the quality of this post and help filteritout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
filteritout is offline   Reply With Quote
Old 06-03-2007, 12:28 PM   #2
Cincy Saturn
Cincy Saturn is on a distinguished road
Cincy Saturn's Avatar
Wrench Re: Engine Jumps at high RPM
Thanks
Could be as simple as the fuel filter being original and not passing enough fuel for the high RPM's. Cheap fix.
The dipstick for the 710 fluid says "ADD"...Where do you buy 710 fluid ?
Add to Cincy Saturn's Reputation
Rate the quality of this post and help Cincy Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cincy Saturn is offline   Reply With Quote
Old 06-03-2007, 12:35 PM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
Default Re: Engine Jumps at high RPM
It could be misfiring. Check to see if the ignition module recall has been done. A call to a local Saturn retailer could tell you if it has been done or not.
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
Old 06-03-2007, 03:40 PM   #4
The earlier L-series cars had known problems with vibration from the front end. 2002 was about the last year of the problem being very common. Check the tire balance. Get a hist of the work done on the car from Saturn to see if any vibration work has ever been done to it.
As for the engine revving cutting out. If you are doing this with the car not moving then you are hitting the rev limiter and the engine is supposed to cut out. Happens at approx 4,000 RPM.
Add to ssicarman's Reputation
Engine shudders at low RPM and high gears puregsr S-Series Tech 3 04-10-2008 07:34 PM
RPM jumps ~1000 @ about 60mph? [Atari] S-Series Tech 6 08-20-2007 01:00 PM
99 sc2 idles high and jumps a bit twincities S-Series Tech 1 07-06-2006 01:10 PM
RPM jumps while braking on 00 SL2 smurf115 S-Series Tech 5 03-22-2005 04:43 PM
rpm seems a little high adan976g Vue General 10 05-05-2004 07:46 AM
