Old 05-30-2007, 02:03 PM   #1
Glasact
Glasact is on a distinguished road
Glasact's Avatar
2009 AURA XR
2002 L-Series 2.2L Sedan
Default Radiator Cooling Fan
The electric radiator cooling fan on my 2000 LS-2 (V6) cycles on and off continuously. It comes on for about 15-20 secs. and then off for about 30 secs. The Ambient temperature has been in the upper 70's to the mid 80's. The cooling resevoir is topped of at the full mark with a 50% mix of dex-cool and the temperature indicator never goes above the 10:00 o;clock position on the instrument panel. It is not showing any signs of overheating at all excect the crazy cycling of the fan. I will also add that the fan cycling starts about 8 minutes after starting a cold engine. Just eneough time to warm up good. I'm guessing it is probably a bad sensor of some sort, but I just don't know where to start looking.
Add to Glasact's Reputation
Rate the quality of this post and help Glasact reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Glasact is offline   Reply With Quote
Old 05-30-2007, 02:24 PM   #2
Default Re: Radiator Cooling Fan
Other than the temperature sensor and the a/c circuit affecting when the fan runs the fan relay is the main switch to allow current for the fan to run. Try swapping the fan relay with another relay in the fuse box.
Old 05-30-2007, 08:41 PM   #3
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
When my thermostat failed it caused the radiator fan to run continously (winter). I unplugged it, but this brought on a CEL. Fix was to replace the 'stat.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-04-2007, 01:18 PM   #4
Glasact
Glasact's Avatar
2009 AURA XR
I swapped the fan relay with the horn relay in the underhood fuse panel. I think that was it. The fan hasn't been cycling since, but the outside temp has dropped too. The horn is working fine but, should I replace that relay anyway?
Old 06-04-2007, 02:23 PM   #5
Let a few more days go by and see, the relay contacts/solenoid may have been borderline for use in the radiator fan circuit but hardly strains in use as a horn relay. In return the hardly strained horn relay is now being counted on for heavy duty use to switch the fan on/off; the fan uses more current and the relay contacts wear a bit more because of it. It may not be worth replacing the relay yet, time will tell.
radiator/ condensor cooling fan speeds? nastyal Vue Tech 9 08-03-2009 10:44 PM
Radiator Cooling Fan not working Zeroherokid S-Series Tech 14 01-17-2008 01:17 AM
Radiator cooling fan relay?? duganator S-Series Tech 3 09-12-2007 01:49 PM
Radiator/AC cooling fan...= dead BEACHBUM S-Series Tech 12 05-23-2006 10:01 AM
Refrigerant and Radiator Cooling Fan? jilly S-Series General 5 10-07-2005 09:37 PM
