Old 05-24-2007, 06:57 AM   #1
lhwilliams
lhwilliams is on a distinguished road
lhwilliams's Avatar
Default Radio Install
I want to install an aftermarket stereo in my 95 SL2. How do you remove the housing to remove the radio?
Add to lhwilliams's Reputation
Rate the quality of this post and help lhwilliams reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lhwilliams is offline   Reply With Quote
Old 05-24-2007, 07:21 AM   #2
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Default Re: Radio Install
Look on the bottom towards the back of the housing....towards where your feet go. There are two clips. Push the center of the clips in, remove the clips. The housing will come off to reveal the 7mm screws holding the radio in.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 05-24-2007, 11:43 AM   #3
Clips? Isn't this a gen-2 sneak-preview dash? There should be two push-center rivets, one on each side of the surround. To remove them without destroying them, push the center-pin IN. This will allow you to pull the whole rivet out. Once both rivets are out, the surround will come away, held only by the wiring to the top switch pod.
To re-use the rivets, push the center-pins back out so they're sticking ABOVE the surrounding rivet head. Push the rivets into place, and then push the center pin so it's FLUSH with the head. In this position, the rivet is locked into place.
Add to madpogue's Reputation
Radio Install MBass S-Series Tech 9 04-17-2009 04:46 PM
xm radio install morgan Aura General 1 09-02-2007 06:32 PM
Radio Install ? oceanjoe89 S-Series Mods 13 08-12-2006 01:43 PM
help with xm radio install freedominco Ion Tech 0 07-08-2005 04:04 PM
95 SL Radio Install 2k1tib Mods and Performance 6 06-16-2003 02:08 AM
