Old 04-10-2006, 04:18 PM   #1
firevswater5
firevswater5 is on a distinguished road
Default New way to "change" Power Sterring Fluid
Today I found a new and more efficient way to to change out the power steering fluid in the reservoir. I was going to try the turkey baster method until I found that we threw out the old on. Then I thought of using the top to a spray bottle (such as found on windex etc) and it ended up working very well. I rinsed out the sprayer with a lot of water and then stuck the hose end into the reservoir and squirted the old fluid into an old oil bottle. I got out about out a little less than .25 qt, but it only took about 5 minutes and I didn't spill a drop. I'll probably do it again next week too to try and get more of the old fluid out.
BTW i refilled with Valvoline High Mileage ATF. I had some left over from my last tranny fluid change so I'll see how it hold up in the PS system.
Add to firevswater5's Reputation
Rate the quality of this post and help firevswater5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
firevswater5 is offline   Reply With Quote
Old 04-10-2006, 04:51 PM   #2
cheapybob
cheapybob will become famous soon enough
2000 SC1
1999 SC2
Default Re: New way to "change" Power Sterring Fluid
I'm surprised you used ATF.
What is the difference between ATF and PS Fluid?
Add to cheapybob's Reputation
Rate the quality of this post and help cheapybob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cheapybob is offline   Reply With Quote
Old 04-10-2006, 05:17 PM   #3
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
why? the majority of PS fluid IS ATF. The only cars that i know of that you cannot use ATF in the power steering is Audi's, as they hate ATF in their PS pumps
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 04-10-2006, 09:08 PM   #4
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
I have a lawn you can mow with nail clippers now that you're done.
Add to eljefino's Reputation
Rate the quality of this post and help eljefino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eljefino is offline   Reply With Quote
Old 04-10-2006, 09:41 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Why would you use automatic transaxle fluid in the power steering reservoir instead of power steering fluid?
Most people at one time or another have encountered a power steering problem with either a power steering pump, hoses, gear box, or rack and pinion. Failures could be anything from noise, leaks, or stiffness when first starting the car. Power steering fluid is designed for power steering systems, different manufacturers sometimes require different fluids. Under NO conditions is ATF to be used in power steering systems. The pressure in a power steering system on hard turns is much higher than that in an automatic transmission under load. Power steering fluid is clear in color. Power steering fluid turns dark because of heat created by the high pressure when held in hard turns. ATF will become very hot under loads and start to break down causing electrochemical degradation, this also happens with power steering fluid but not as fast was with ATF. Once this process starts, your power steering pump and rack & pinion begin to clog with sludge and varnish deposits. The sludge and varnish can cause stiffness, leaks, or complete system failures.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-10-2006, 09:43 PM   #6
andy_95sl2
andy_95sl2's Avatar
because most powersteering fluid IS automatic transmission fluid.
maybe not exact, but its chemical structure is alike, so its safe to use. Look on the back of a bottle of ATF and a bottle of PS fluid, you'll see they're almost alike
Old 04-10-2006, 10:20 PM   #7
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Most manufactures are going to atf in the p/s system. Thats one less diffrent fluid they ahve to keep in the factory. Alot of asian cars do it and chrysler is getting big into it now
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 04-10-2006, 11:50 PM   #8
wolfman
wolfman's Avatar
Anybody that thinks the powersteering system of a car runs hotter than the automatic transaxle does is deluding themselves. With few exceptions, ATF can be used in powersteering systems (especially synthetic ATF which I specifically recommend) can be used in place of ATF and will perform as well if not better and for longer.
Add to wolfman's Reputation
Old 04-11-2006, 02:15 AM   #9
bluebunny524
bluebunny524 is on a distinguished road
just to add, audis and vws can't use atf or ps because they share the power steering and clutch systems off the same hydraulic system; the seals they use are designed for higher pressures and require different lubrication. Thus you need to run lucas oil in them ( NOT the same as the lucas additive). While the fluid is very expensive I've achieved 450,000 miles on a pump, so it must work. The lucas oil is more of a non compressible lubricant whereas atf is more of a non compressible solvent.
Add to bluebunny524's Reputation
Rate the quality of this post and help bluebunny524 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bluebunny524 is offline   Reply With Quote
Old 04-11-2006, 08:35 PM   #10
Bluesideup
Bluesideup is on a distinguished road
So it's OK to use Mobil 1 Synthetic ATF in our 2000 SL1 power steering? The book lists some GM fluid.
The newer Audis and VWs do not use power steering fluid for the clutch, they use the brake fluid. VW fluid is a mineral fluid and putting ATF in there will really cause problems.
Add to Bluesideup's Reputation
Rate the quality of this post and help Bluesideup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bluesideup is offline   Reply With Quote
"S" Series automatic transaxle fluid/filter change wolfman How-To Library 86 08-15-2016 11:32 PM
Dealer recommended "cabin" air filter change?? 08auraj Aura General 10 05-30-2009 12:50 PM
Saturn Hybrids Drive "The Road to Change" to the Presidential Inauguration Charlie Vue Green Line 1 01-14-2009 03:28 PM
Is there a "step-by-step" how to" procedure to change the ATF fluid? kim_lombard Vue Tech 0 07-25-2007 11:24 PM
P/S pump seems to "mist" area around it with fluid auxmike S-Series Tech 5 05-04-2004 10:37 PM
