Closed Thread
Old 09-14-2005, 02:21 PM   #41
globasco
globasco is on a distinguished road
Roll Eyes Re: Changing the ECTS Coolant Temp Sensor (with pictures)
Hey guys-- silly girl question.
Would a broken ECTS Sensor cause my fan to not turn and, in turn causing my poor lil saturn to overheat when idling/in slow traffic???
Add to globasco's Reputation
Rate the quality of this post and help globasco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
globasco is offline
Old 09-14-2005, 02:38 PM   #42
Tiger
Tiger is a jewel in the roughTiger is a jewel in the roughTiger is a jewel in the rough
Tiger's Avatar
Default Re: Changing the ECTS Coolant Temp Sensor (with pictures)
If the ECTS is not working properly, the fan will not turn on. Also, fans go bad. Also, it may be good to check for a blown fuse, at least that is what I would do. No fan will cause overheating problems at idle/in slow traffic. If you turn the AC on, the fan should turn on. If it is coming on with AC, the fan and the fuse are probably good. ECTS may be the culprit. That is my understanding. I am a silly Social Worker. The experts here can direct you better.
Truth alone triumphs, not untruth.
Add to Tiger's Reputation
Rate the quality of this post and help Tiger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tiger is offline
Old 10-02-2005, 02:44 AM   #43
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
Thanks for all of the information, everyone. I changed the engine coolant temperature sensor myself with the jacking-up-the-driver-side procedure. I have a 1999 Saturn SL1 with slightly under 30,000 miles on it. The removed temperature sensor did not seem to have any cracks in it, but it is good preventive maintenance, as wolfman or someone else wrote.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline
Old 10-02-2005, 02:51 AM   #44
edlee
1999 SL1
I would also like to add that I found it hard to remove the air intake on my SL1 because of that narrow tube that branches off the middle of the main air intake. So what I did instead was remove the battery as someone else suggested.
If I had to do the procedure again, I would place a towel or rag under the ECTS to catch the half a cupful or so of coolant that leaks out as someone else photographed.
edlee is offline
Closed Thread
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 10:45 PM
Ref Mike's "How-To" : Change the ECTS Coolant Temp Sensor w/pics! Luke S-Series Tech 2 06-20-2005 02:19 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
Here's my famous cracked Coolant Temp Sensor Scan {ECTS} auxmike S-Series Tech 36 01-30-2005 02:17 PM
