Old 02-11-2020, 02:57 PM   #1
Ccrussell
Ccrussell has a spectacular aura aboutCcrussell has a spectacular aura aboutCcrussell has a spectacular aura about
1999 SL1
1999 SC2
Default Transmission repairs
Hi,
I purchased a 400 dollar sc2 a few months ago, automatic, would barely move under its own power. I recently torqued the input nut and got that out of the way. Didn't seem too loose but did turn a bit until the torque value was reached.
Next is a new valve body with the sonnax upgrades.
I pulled the old filter while draining the oil and was horrified to see small metal particles suspended in the oil. BTW there was no magnet under the filter.
Is this the kiss of death? Otherwise so far things looked clean inside.
Still hoping for a 5 speed to swap in its place but this is it for now.
Thoughts? Car had barely had any movement forward or reverse gear before I started tearing into it
Add to Ccrussell's Reputation
Rate the quality of this post and help Ccrussell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ccrussell is offline   Reply With Quote
Old 02-11-2020, 04:00 PM   #2
onlinebiker
Default Re: Transmission repairs
Junkyard tranny - out of a matching car with a connecting rod stuck through the engine block.... That way it's a high probability that the transmission worked at the car's demise.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-11-2020, 07:12 PM   #3
Ccrussell
1999 SL1
1999 SC2
Yes but will this trans still work?
Old 02-11-2020, 08:15 PM   #4
onlinebiker
Dunno.
My crystal ball broke..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-12-2020, 02:49 AM   #5
They didn't work from the factory. I used to have dealer documentation to prove it from a '97 SW2 that got a rebuilt unit at 22k miles and when I got the car at 114k miles...it needed ANOTHER MP7 (only about 90k on it this time)!
Screw that, throw a manual trans in it and be done with problems.
Old 02-12-2020, 06:45 AM   #6
Ccrussell
1999 SL1
1999 SC2
Yes probably true. Working on finding a donar car.
Old 02-12-2020, 02:04 PM   #7
toggenburg
toggenburg's Avatar
The bulk of my 20 + vehicles have been automatics, and only with the Saturn S's did I need to change fluid every 30K miles.
However; that being said: Look, not everyone of us wants to clutch their way through bumper to bumper traffic. It gets weary.
My daughter has a Nissan Versa Note hatchback automatic trans, gets 44 mpg consistently, her hubby has a Nissan Versa Sedan with a 5 speed, he gets about 35 mpg.
If you like clutching, go ahead.
If you don't miss clutching, go ahead.
Old 02-12-2020, 06:06 PM   #8
onlinebiker
I have both...
It occasionally gets confusing - stomping on the brake to shift.....
It was worse going from.Harley to Norton or Triumph....
HD had left foot shifting - Norton and Triumph had right foot.... Except the 77 Triumph - that was on the left......
All time worst - the 68 Triumph chopper I built.
Left hand throttle (that worked backwards) - left hand front brake. Right hand tank mount shifter - right foot.clutch - left foot rear brake.....
You got used to it after a while...
Bonus - thieves couldn't ride it....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-12-2020, 10:00 PM   #9
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
1996 SW2
"Bonus - thieves couldn't ride it...."
That's pretty much why, in addition to a car alarm (and the fact that there are more enticing theft targets out there) the "passive theft deterrent system" in my SW2 IS the manual tranny lol.
Add to Mister_Cee's Reputation
Rate the quality of this post and help Mister_Cee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mister_Cee is offline   Reply With Quote
Car Repairs 01SL1SATURN S-Series General 11 09-10-2010 08:37 AM
Repairs You Don't Want on Your Car BarnOwl S-Series Tech 38 05-15-2007 02:52 AM
Vue Repairs. KoolVue Vue General 8 02-23-2005 10:00 AM
A/C Repairs 92saturnsl2 Miscellaneous Tech 8 07-15-2003 07:42 PM
Repairs need on '94 SL2 kungfulife S-Series Tech 7 02-25-2003 10:20 PM
