Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Red Line
Old 12-27-2019, 10:17 PM   #1
KEP3
KEP3 is on a distinguished road
2007 AURA XE
Default Small "horns" under hood by headlamps
I noticed on my Skys there are little white plastic "horns" attached to under-bonnet near the headlamps. The don't seem to be attached to anything. Any idea what they're use is?
Add to KEP3's Reputation
Rate the quality of this post and help KEP3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KEP3 is offline   Reply With Quote
Old 01-29-2020, 04:55 PM   #2
ScotSHO
ScotSHO is on a distinguished road
Default Re: Small "horns" under hood by headlamps
Without seeing, my guess would be anti-deer noise makers that were stuck on by a previous owner?
Add to ScotSHO's Reputation
Rate the quality of this post and help ScotSHO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ScotSHO is offline   Reply With Quote
Old 01-31-2020, 10:57 PM   #3
KEP3
2007 AURA XE
I don't think so. They were on my 2007 Sky as well which I ordered from the factory. They're white plastic located behind the headlights but they don't seem to connect to anything.
Old 01-31-2020, 11:30 PM   #4
ssicarman
ssicarman's Avatar
Pictures?
Add to ssicarman's Reputation
Old 02-03-2020, 09:41 AM   #5
ScotSHO
So I've been looking at a few Skys on eBay (thinking about picking one up!), and I think I see the horns you mentioned. They look like their job is to direct moisture out of the headlight housing and have it drip in an advantageous spot?
Old 02-05-2020, 10:10 PM   #6
KEP3
2007 AURA XE
Originally Posted by ssicarman View Post
Pictures?
For some reason my post refused to show the pix I had linked.
Let's try this.
https://drive.google.com/open?id=1bm...qABW4nCddSVy5r
Old 02-05-2020, 11:25 PM   #7
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Here is a better view - 2nd image down on post #1 - Jul 1, 2011
https://www.skyroadster.com/threads/...ht-swap.38673/
Look at post #13 - Jul 2, 2011 at the above url
..."Now get rid of the next-to-useless funnel-like white plastic sippy cups."
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-06-2020, 12:08 AM   #8
focusofheart
The above URL could stop working so I am adding the image through this forum. I was also thinking that those white plastic pieces might be there to protect or hold something in place when the hood is closed - maybe that black wire.
Just a thought.
Old 02-06-2020, 11:54 PM   #9
ssicarman
ssicarman's Avatar
Keep in mind that it has been the better part of 12 years since I have worked on a Saturn and the Sky was a very small part of what we worked on at the dealership.
Looking at the white part in relation to the screw and wheel assembly at the narrow end of the white part I wonder if it is not a guide for a screw driver of some kind for what should be the headlamp adjuster.
I would imagine that there is a way of getting a screwdriver into/through the white part (the white part as a guide) with the hood closed to move the adjuster.
Old 02-07-2020, 01:21 AM   #10
focusofheart
... Looking at the white part in relation to the screw and wheel assembly at the narrow end of the white part I wonder if it is not a guide for a screw driver of some kind for what should be the headlamp adjuster.
I think you solved the mystery!
Old 02-07-2020, 01:59 AM   #11
focusofheart
post #4
"They are adjustable. Open the hood and look at the back of the headlight housings. The white "funnels" are there to guide a screwdriver to the adjustment screws. You reach them through the side marker lamp opening after removing the side marker lamp assembly from the car."
read the thread
https://www.skyroadster.com/threads/...dlights.34210/
Old 02-07-2020, 11:23 AM   #12
ScotSHO
Wow. That explains it! Thanks for that!!!!!
A Goodyear brand "small hose" story pierrot L-Series General 0 12-13-2013 02:20 AM
Small "airbox" on top of radiator bronzestarvue S-Series Tech 14 02-23-2009 05:19 PM
"Small Evaporative Leak" mr. ed S-Series Tech 5 10-25-2006 07:39 PM
