Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 11-26-2019, 03:05 PM   #1
rgiegler
rgiegler is on a distinguished road
Default Drivers Seat Too Close to steering wheel
I can't push the driver's seat back any further. Is there a way to adjust it so it's not so close to the steering wheel? Or, move the rails its sits on further back?
Add to rgiegler's Reputation
Rate the quality of this post and help rgiegler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgiegler is offline   Reply With Quote
Old 11-26-2019, 03:42 PM   #2
Default Re: Drivers Seat Too Close to steering wheel
If you can, did you move the seat forward? If something hard fell onto the seat rails, this may prevent seat travel as it jams it in place. Moving the seat in the opposite direction may loosen and allow travel or reveal where it jammed. Rocks, pebbles, a Lego piece, etc. If rails are rusted, some penetrating oil can loosen things. White grease for continual lube.
Old 12-20-2019, 11:07 AM   #3
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Power or manual seat? Does it move at all?
My old SL1 had a stuck manual passenger seat. There was a stiff wire that ran from one side of the seat adjuster to the other that had broken. So the track wasn't being released on one side. I replaced it with a piece of coat hanger wire, without removing the seat.
https://www.youtube.com/watch?v=v2k8qPoB8cI&t=189s
FS: VXR steering wheel, interior bits, seat covers nicolas_p Astra General 9 09-18-2018 04:05 PM
Replacing steering wheel - how do I make sure coil behind steering wheel is ok? vikasevan S-Series Tech 2 12-29-2014 01:32 PM
Open seat zipper - how to close? usa4624 S-Series General 1 07-18-2013 05:03 AM
Mesh Support under drivers seat... (common caved in drivers seat) mattachuz L-Series General 8 02-12-2012 06:22 AM
pass. seat track on drivers seat? fetchitfido S-Series Mods 4 10-04-2006 10:40 AM
