Old 12-04-2019, 06:27 PM   #1
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
Default 99 sw2 seems to run cold
I have had many Saturns over the years, thanks to this forum. Currently i am driving a 99 SW2 with the 99a engine, no air pump, but it seems to be running a little colder than the rest. The gauge goes to just over 1/4 mark. i have replaced the thermostat and the ects. minimal gain. The car does warm up but it does take a while. Wondering if I missed something or gauge just reads low.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
Old 12-04-2019, 06:39 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 99 sw2 seems to run cold
Check the heater hoses where they come out of the dash and into the engine compartment, are they both warm when the car is up to temperature? It's possible the heater core may be plugged or partially plugged. Do you have a way of reading the actual coolant temperature? I would not trust the gauge 100%. On a side note, if it's really cold out, Saturn actually recommended leaving the blower fan on the first or second speed to allow the engine to warm up quicker.
Add to bluesl2's Reputation
Old 12-04-2019, 06:45 PM   #3
me.theuser
2002 SL1
2001 SL2
Do a radiator pressure test my 2001 had a cracked end cap and didn't leak a noticeable amount of anti-freeze
autoparts store should allow you to rent one, you might need to rent an adapter kit for it as well
Also check the cap
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-04-2019, 07:16 PM   #4
Did you use a new Stant thermostat?
Is the top radiator hose (drivers side) hot going into the radiator?
When you replaced the ECTS, did you check for corrosion inside the wiring plug, it could be green and needs cleaning or a new one spliced on? And what condition is the harness wiring going to the ECTS, all 1 piece, or correctly spliced (solder joints only and shrink tube to seal)?
If all else checks out good, maybe add a piece of cardboard in front of the radiator, just like about halfway up to block the wind.
Old 12-04-2019, 09:20 PM   #5
marmitage
marmitage's Avatar
Also check the cap - good
Did you use a new Stant thermostat? Yes
When you replaced the ECTS, did you check for corrosion inside the wiring plug, it could be green and needs cleaning or a new one spliced on? clean good splice
And what condition is the harness wiring going to the ECTS, all 1 piece, or correctly spliced (solder joints only and shrink tube to seal)? yes very nice shape
Will let you know tomorrow on hose temp at rad and dash after I drive into work.
Will see if I can get hold of pressure tester.
I have replaced a heater core before hope that's not it. This one does get hot but takes longer than the other Saturn, will melt you if you drive long enough in town.
Cardboard will be this weekend if not fixed -0* on Friday
marmitage
99 Sw2 Daily driver
Old 12-04-2019, 10:53 PM   #6
Just over a quarter seems good. trottida should be along shortly to post his picture.
Add to Waiex191's Reputation
Old 12-05-2019, 10:49 AM   #7
trottida
trottida's Avatar
LOL - here you go...
Take a look at this post for more details >> http://www.saturnfans.com/forums/sho...48&postcount=6
...or the entire thread for that matter >> http://www.saturnfans.com/forums/sho...48#post2290148
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 12-05-2019, 11:14 AM   #8
marmitage
marmitage's Avatar
forgot right away when i got in so less than 10 min from shutoff after 15 min drive (did have heat after 5 miles)
hose at rad is warm to touch not overly hot
hot
hoses at dash warm but cooler than at rad
working on pressure tester
will upload gauge pick shortly
marmitage
99 Sw2 Daily driver
Old 12-05-2019, 12:23 PM   #9
marmitage
marmitage's Avatar
Ok here is my picture. if a needle off either way is good then I am probably good. There is warmth it just takes a little longer than the 97. Rebuilding a motor for this anyway....
Just used to it being at 3/8..
marmitage
99 Sw2 Daily driver
2004 Vue Manual Tran Shuddering on Cold Start in Cold Weather sixstringmonk Vue Tech 5 02-20-2012 08:28 PM
Good cold start, trouble starting when not cold, fast idle 2001 SL2 composerchris Community Center 2 12-05-2008 03:02 AM
04 3.5l hard to start in cold (45 degree cold) SaturngirlSc2 Vue Tech 8 04-02-2008 07:08 PM
Won't idle when cold; hard starting when very cold photoworks S-Series General 5 02-18-2008 01:24 PM
