Old 11-10-2019, 01:59 PM   #1
onlinebiker
Default Surging.
I've an annoying one on my 99 SC2.
I got the car with a rod thru the engine. ($300) and bought another 99 with a rusty undercarriage, and swapped engines.
All went easy.
It starts and runs well - but a bit noisy - body rattles which quiet down as it heats up. Good compression 190+ cold. Spark plug readings as textbook perfect.
Very good acceleraton off the line. Decent gas mileage. No SES codes.
I notice a slight surging in overdrive between 45 and 55.
I suspected it might be a knock sensor - but a new one made no difference.
I suspect the ECM has been changed as my reader says ""ABS not supported" although the car does have ABS (Not hooked up) - and it shows a fault for the keyless entry - and the car does not even have power locks.
Any thoughts?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
onlinebiker is online now   Reply With Quote
Old 11-11-2019, 01:08 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Surging.
The surging issue may be EGR related, try swapping the valve off your old engine then driving it. How old are the plugs/wires?
Add to bluesl2's Reputation
Old 11-11-2019, 01:50 PM   #3
onlinebiker
Not sure - but wires appear new. Plugs do not show errosion - so I assume they're fairly new as well.
Will try another EGR. I have a few...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-14-2019, 12:42 PM   #4
onlinebiker
Am now getting a p0326. Still feeling the hesitation.
Live data on my scanner shows erratic advance under all conditions. At steady speeds the advance is between 11 and 34 degrees btdc. ..
Thoughts?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-14-2019, 01:42 PM   #5
onlinebiker
Update. I had to run to town. So once the car was full warm - the advance ran between 40 - 44 btdc at 62mph and 55 mph. No surging.
Grrrrrr....
It's easier when stuff just breaks.
Easier to find...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-14-2019, 02:31 PM   #6
The surging as the engine warms up is an incorrect air flow through the throttle body. It is usually a wear issue and time to go shopping for one with good bearings and now visible wear. This is a mechanical failure unless you or a previous owner have playing with the static air adjustment screw.
Old 11-14-2019, 02:42 PM   #7
onlinebiker
On the way back from town it started doing it again. Full hot (192f) the advance drops down to 10 to 25 degrees....
I have opening day of deer season tomorrow - so I guess the problem goes on hold.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-14-2019, 02:46 PM   #8
I suspect the bearings are way gone or you have a good air leak between the throttle body and the cat outlet.
Old 11-14-2019, 02:54 PM   #9
onlinebiker
Ok.. I have spares. Any good way of testing one?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-14-2019, 05:40 PM   #10
Hold the throttle body only straight out in front of you and wind it full open and see if you can feel any motion in the throttle shaft only back and forth towards you. There should be a rubber cap on the static air adjustment screw Inspect throttle bore for any wear.
No wear or motion allowed.
Old 11-14-2019, 06:17 PM   #11
onlinebiker
Thanks!
I dunno when I will get to it. I have 5 deer tags - my SO has 2, and my sister has 2. I expect to be busy butchering deer for the next couple weeks. Fortunately it is cold enough to hang them outside. I have my car gantry (with Saturn wheels) set up for hanging deer..
I'll post a picture when we get some hanging...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-25-2019, 01:48 PM   #12
onlinebiker
I got caught up on hunting and got some time to wrench...
I checked the throttle body - and there was very little play on the axis to body fit... I checked another one from another 99 - and it seemed to have none at all - so I swapped the body - with the TPS and air....
It did not change at all...
My INNOVA 3160 tells me that the flat spot is caused by spark being retarded - under 20 degree btdc...
I changed the knock sensor and no change.
What else could be causing it to retard?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-27-2019, 01:31 AM   #13
TomM96
I dunno the Ig timing determinants, aside from KS... maybe mixture?
FDryer should chime.
I wanted to complement the designer's choice of material for the fenders on the
tow rig (seen in another thread).
Add to TomM96's Reputation
RPM surging 99 SL2 Mooseparade S-Series Tech 17 06-30-2018 08:13 AM
SL2 surging jagplates S-Series Tech 15 04-17-2015 02:07 PM
Car Surging Tannerf Ion Tech 1 02-10-2013 12:04 AM
Surging rubicon4x4 L-Series Tech 3 12-23-2010 01:04 AM
93 Sl2 Still Surging boatmoter S-Series Tech 10 05-18-2008 10:48 AM
