Old 09-16-2019, 02:41 PM   #1
Shive
Shive has a spectacular aura aboutShive has a spectacular aura aboutShive has a spectacular aura about
Shive's Avatar
2002 L-Series 2.2L Wagon
2003 L-Series 2.2L Wagon
Default 2002 LW200 Power Steering Quit
Power steering was working fine. I parked the car and when I restarted it the power steering did not work. There appears to be a small leak under the reservoir. I cleaned it up and pumped out the reservoir two times and replaced the fluid. Power steering still does not work at all.
What should I check next ?
Thanks
Add to Shive's Reputation
Rate the quality of this post and help Shive reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shive is offline   Reply With Quote
Old 09-16-2019, 06:15 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 2002 LW200 Power Steering Quit
It might be a long shot, but take the power steering pump off the intake camshaft and see if the end has broken off. I have seen that just once but it may be worth a look to see. The pump is driven by the intake camshaft.
Add to bluesl2's Reputation
Old 09-16-2019, 08:18 PM   #3
Shive
Shive's Avatar
That could be it because I don't think it pumping at all.
I'll check that.
Thanks
Old 09-17-2019, 06:11 AM   #4
Dsaturn
2001 L-Series 2.2L Sedan
Take the return line off the pump and put it in a mason jar or something like that, Start engine for a second or two and see if fluid is being pumped into it. Keep it higher then the pump so you know gravity is not at play. Get A helper to turn key so you can watch flow, it should pump pretty fast.
https://www.infowars.com/ The answer to 1984 is 1776.
Add to Dsaturn's Reputation
Old 10-26-2019, 12:03 PM   #5
Shive
Shive's Avatar
Thumbs Up Re: 2002 LW200 Power Steering Quit
Replaced the power steering pump. Problem fixed.
Thanks to everyone who helped me out.
Shive
Old 10-26-2019, 12:13 PM   #6
bluesl2
bluesl2's Avatar
Was the end broken or did it have an internal problem?
Old 11-17-2019, 06:08 PM   #7
Bellyacre
Bellyacre is on a distinguished road
Hi,
I have LW200 with 310k miles. What fluid did you use?
I would prefer to put ATF fluid in mine. But, owners manual shows differently.
Add to Bellyacre's Reputation
Rate the quality of this post and help Bellyacre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bellyacre is offline   Reply With Quote
Old 11-17-2019, 06:43 PM   #8
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
With 300+k miles atf will work fine. It is less expensive but may leak more. Lucas makes a power steering stop leak.
Add to 02 LW300's Reputation
Old 11-17-2019, 07:48 PM   #9
Originally Posted by Bellyacre View Post
Hi,
I'm a fan using the recommended fluid for the power steering system. Power steering fluid is specified for that unit because the hydraulic pressure is much greater there than in the transmission. When transmission fluid is under the pressure brought to bare by a power steering system it causes the fluid to bubble and thus weakens the system. Now, you're probably not going to use much fluid if you just want to add, but why use the wrong fluid? Power steering fluid is more expensive than ATF, but not extremely so.
Generic brands one could find at any auto parts store or WalMart will do just fine. Some brand examples: Johnsens's, Valvoline, Prestone, Castrol, AutoZone, O'Reillys, NAPA...lots of options (of course there's always AC Delco). Just make sure that they meet the equivalent part number shown in your Owner's Handbook. Some brands may state on the container that they are suitable for a particular brand only in specified model years.
FWIW, I use Johnsen's and have for many years.
329,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Add to pierrot's Reputation
Old 11-28-2019, 02:38 PM   #10
Bellyacre
Thanks, Pierrot.
I used a clear hose attached to the low pressure hose. I had lots of dextron III on hand. I jacked, and turned from lock to lock. Until the old black fluid disappeared, and the hose was now filling with red. After a couple of days. I realized it could be better. So, I flushed it this time with Valvoline power steering fluid. I could tell as soon as I turned it on the jacks. (engine off) Much smoother than the ATF. Thanks for the responses.
2001 LW200 2.2 leak at cam power steering pump interface jchiko L-Series Tech 7 11-11-2010 05:27 PM
96 SW2 Power Steering Quit towcar96sw2 S-Series Tech 8 01-06-2009 06:57 PM
2002 LW200 - Power Loss usa4624 L-Series General 4 05-02-2007 11:06 PM
2001 LW200 Blower Quit fish_skier L-Series General 4 08-21-2006 11:01 PM
power mirrors; 2002, LW200 napa1 L-Series Tech 0 06-06-2005 08:47 AM
