Old 08-20-2016, 12:53 PM   #21
far2grumpy
far2grumpy's Avatar
Default Re: Bad ECU or OBF Replacement Throttle Body
Originally Posted by Vladymere View Post
When I start the vehicle up it runs fine until the ECU leaves closed loop operation and enters open loop operation then it runs like crap.
I'm just a bit confused about the described sequence ... engine should start in Open Loop and then move to Closed Loop when possible ...
Here's FSM extract:
Run Mode
The run mode has 2 conditions called Open Loop and Closed Loop. When the engine is first started and the engine speed is above a predetermined RPM, the system begins Open Loop operation. The control module ignores the signal from the heated oxygen sensor (HO2S). The control module calculates the air/fuel ratio based on inputs from the ECT, MAP, and TP sensors. The system stays in Open Loop until meeting the following conditions:
The HO2S has varying voltage output, showing that the HO2S is hot enough to operate properly.
The ECT sensor is above a specified temperature.
A specific amount of time has elapsed after starting the engine.
Specific values for the above conditions exist for this engine, and are stored in the electrically erasable programmable read-only memory (EEPROM). The system begins Closed Loop operation after reaching these values. In Closed Loop, the control module calculates the air/fuel ratio, injector ON time, based upon the signal from various sensors, but mainly from the HO2S. This allows the air/fuel ratio to stay very close to 14.7:1.
In any case it sounds like you found a really good bargain if dealer is going to repair for $115.
Old 08-22-2016, 11:26 AM   #22
Vladymere
Vladymere has a spectacular aura aboutVladymere has a spectacular aura aboutVladymere has a spectacular aura about
2008 VUE Red Line
far2grumpy,
I have the terms closed loop and open loop confused (reversed). The vehicle when cold would start and run without issue for 2.5 to three minutes and then operation would go to hell. You could turn the vehicle off for a short duration (10 seconds, 30 seconds) restart the vehicle and it would again run well for a short duration.
I believe that while running in open loop (what I called closed loop) that it ran well as it was running on internal programming and ignoring some (or many) of the sensors. Once the ECU switched over to all external sensor input for operation performance would fail.
I do know that the original throttle body was bad as one of the throttle position sensors (which I no longer remember and would have to meter it again which I can do if requested) measured infinite ohms.
Now that the ECU has been replaced with the used 2008 Chevy Malibu ECU and programmed by the dealer all is well.
The dealer charged a total of $127.90. $115 for re-programing and $4.25 for shop supplies and $8.66 tax. I am not unhappy with the charges.
far2grumpy, Thank you so very much for the advice and documentation you provided. You help has been instrumental in the repairs being completed.
I would like to think that I have still, in the end, saved money over having the vehicle towed to a dealer for diagnosis and repair. Also, having made my living with my hands for all of my life ( and having been and automotive service technician by training and employment having the left the field over 37 years ago) I just don't trust the work of others. I don't always make the correct repairs the first time around but when it is still wrong I know in the end what I failed to do.
Vlad
Add to Vladymere's Reputation
Rate the quality of this post and help Vladymere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vladymere is offline   Reply With Quote
Throttle Body Replacement Glen Williams L-Series General 3 10-03-2015 05:25 PM
03 L300 no start unless the throttle motor/ throttle body unpluged Woody117 L-Series Tech 2 12-25-2012 07:33 PM
2003 Vue, 1800.00 dollar throttle body replacement and now a 675 BCM replacement??? Suicidns13 Vue General 8 03-04-2010 05:46 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
Fuel Injector/ Throttle Body Replacement? LinuxPunk S-Series General 4 09-02-2004 11:47 AM
