Old 07-07-2019, 08:16 PM   #1
Jbear
Jbear has a spectacular aura aboutJbear has a spectacular aura aboutJbear has a spectacular aura about
1999 SL1
Default Length of brake line
Can any of you tell me the overall length of the metal brake line from the proportioning valve to the right front (passenger side) caliper?
I need to replace the line. I'm using Nicopp, I have all the tools for flaring and so on.
It looks like I'll have to get under the car to get the various clips loose to pull this out.
My idea (because of some physical issues, getting up and down from the ground is pretty difficult for me.) I'm thinking I might be able to pull the old line and put in the new one at the same time (bending as I go) if I know how long a piece to cut. I can put on the fittings and flare the ends beforehand.
Not sure this will work, but thought it might be worth a try. The first obstacle is the plastic holder that all the lines run through, just below the proportioning valve. I'm still looking for how to take that off to get the old line out.
Add to Jbear's Reputation
Rate the quality of this post and help Jbear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jbear is offline   Reply With Quote
Old 07-07-2019, 08:32 PM   #2
Default Re: Length of brake line
Here you go:
http://www.saturnfans.com/forums/sho...d.php?t=236929
I pulled these lines in and as I went I bent in place. I like the bend the new line to match the old line technique better.
http://www.saturnfans.com/forums/sho...&postcount=135
Add to Waiex191's Reputation
Old 07-08-2019, 10:53 PM   #3
Jbear
1999 SL1
Thanks, Brian, I appreciate it, but, um... I needed the length of the line to the front passenger side.
I'll keep the info for the 2 rear lines in case I need it later.
Old 07-27-2019, 09:31 PM   #4
Jbear
1999 SL1
I kept the old line after I removed it so I could measure it. Just got around to it. The length of the line to the front passenger side is 72" (6 ft.). I allowed an extra couple of inches from the actual measurement for the ends I cut off to get the fittings.
I'll be changing the other front line in a few days, I'll post that measurement as well. Maybe that will be helpful for someone else.
Old 07-27-2019, 09:37 PM   #5
454cid
Wow, I never would have guessed it was that long. I don't know how it's routed though. Mine looks pretty crusty, and I'm a bit nervous about it.
1999 Chevy K3500
Add to 454cid's Reputation
Old 07-27-2019, 09:52 PM   #6
onlinebiker
Proportioning valve?
I just did the brakes on the 92 SC - and I didnt see one....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 07-27-2019, 11:23 PM   #7
It is part of the master cylinder, there are 2 of them.
Old 07-27-2019, 11:45 PM   #8
onlinebiker
Ok..thanks.
Didn't know they had one. So is it adjustable, or do they have two MCs for drum vs disc rear?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 07-28-2019, 06:29 AM   #9
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Stupid question time: what if the two rear lines were switched at the master cylinder, how catastrophic would that be?
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 07-28-2019, 10:00 AM   #10
Goggles Pisano
1999 SL1
Once again, thanks fdryer:
Originally Posted by fdryer
the brakes are physically split into two separate diagonal brake systems from the master cylinder making the right rear/left front one side and the left rear/right front the other side. Not the fronts as one half and the rears the other half. Having split the brake system into two diagonals has always been this way.
The search box is your friend.
Old 07-28-2019, 10:35 AM   #11
If you had ABS, swapping the lines would be bad as the system would let up on the wheel with the most traction.
Old 07-28-2019, 12:17 PM   #12
The ABS is cheap tri-channel, not quad channel. Fronts can be turned off individually but the rear is turned off as a pair so swapping the lines has no impact.
I understand the concept of the diagonal hydraulic brake setup but all it does is make bleeding harder than it should be...once there's a hole in any line you have no brake pressure without the parking brake. If it were a proper front/rear setup you'd only have to jack up the car once to bleed, not 2+ times.
Old 07-28-2019, 12:20 PM   #13
Jbear
1999 SL1
I've seen the diagrams of the brake lines in a diagonal configuration, and another diagram where they are not. Mine are not. But I don't know if they're still set up RF/LR, LF/RR, or not.
The one I just replaced runs from the driver's side left of the MC/PV down under the dash/firewall, across to the front right (passenger side) wheel. It's a little hard to trace, most of the line isn't visible, it's tucked up above and behind things. The rear passenger side runs down the driver's side alongside the driver's side rear line, then near the rear wheel it bends and runs across to the passenger side. I replaced the part that runs across not long ago. I'm replacing both driver's side lines in a couple of days, and probably the remaining steel portion of the RR line.
Old 07-28-2019, 12:25 PM   #14
Goggles Pisano
1999 SL1
Having a discussion with the father-in-law as we install these brake lines. It's an SL1 with no ABS, but he wants to not have them diagonal, with his thinking that if brakes go out the car would want to snap into a spin. I'd rather keep it the way it is, thinking the car would pull violently to one side or the other doing it that way.
I don't anticipate having brakes going out like that in my future which is why we're doing this work, but still. Also, wouldn't it throw off the order of brake bleeding?
Old 07-28-2019, 12:49 PM   #15
ssicarman
ssicarman's Avatar
Your father in law needs to rethink things. Dual diagonal system.
One front and one rear on the opposite side are on a circuit and the other circuit is the other front and and other rear.
This means that if one circuit goes you will get, in theory, even braking on each side rather than all of the braking on one side of the car.
Add to ssicarman's Reputation
Old 07-28-2019, 01:01 PM   #16
onlinebiker
The diagonal braking - as I had it explained.
If the front brakes were on one side of the MC and the rear were on the other - if your brake differential light went out - if you lost the rear brakes first ( more likely too as the rear lines rust out first) you would still have 90 percent braking - and you wouldn't be aware of it. Or if the front went first - you would only have 10 percent braking. If you then lost front you have zero braking.
However- with diagonal -- you will always have 50 percent braking should one side fails - and you WILL be aware there is a problem.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 07-28-2019, 02:50 PM   #17
Originally Posted by onlinebiker View Post
Ok..thanks.
Same MC for both disk or drum rear.
Old 07-28-2019, 03:35 PM   #18
Goggles Pisano
1999 SL1
It was a moot point anyhow, because if he was going to accomplish that, he would've remembered to switch the fittings to the master cylinder!
FFR: Brake line length Waiex191 S-Series Tech 5 04-07-2019 02:58 PM
brake hose to brake line union? slugbug S-Series Tech 3 06-25-2018 11:27 PM
Length of brake line needed to redo all four lines? dbsanfte S-Series Tech 2 11-08-2012 06:22 AM
Are the left/right parking brake cables diff length??? SUPERCHARGE S-Series Tech 8 03-06-2010 08:31 PM
brake line gone wojtek_f S-Series Tech 10 04-02-2008 02:20 PM
