Old 07-20-2019, 01:04 PM   #1
cchrrice
cchrrice is on a distinguished road
Default 2006 vue cant6 reset check engine light
My vue melted a coil pack and spark plug. Set 10 codes. Repaired the damage, but can't reset codes. How do you reset a hard code in ecm.
Add to cchrrice's Reputation
Rate the quality of this post and help cchrrice reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cchrrice is offline   Reply With Quote
Old 07-20-2019, 03:16 PM   #2
Default Re: 2006 vue cant6 reset check engine light
10 codes?! Are they all related to the spark plug and coil pack? Did you or anyone determine the reason for this issue?
Some errors that are fixed are detected with the next startup, moving the stored error code to another memory location while turning off the engine light. Other errors remain that aren't corrected and leave the engine light on. When all errors are corrected the engine light turns off. And, some errors requires three engine/drive cycles before the engine light is turned off. These errors are emissions codes and the on board self diagnostics needs to see several driving cycles without these error codes coming back before turning off the engine light. One example is the loose, leaking, damaged gas cap or evap system lines leaking fuel vapors. Once repaired, a few days of driving turns off the engine light since correct repairs are made but the OBD II system tests it to be sure the error was fixed. After repairs and the engine running fine, you can wait a day or so to scan for any new or remaining error codes. If you have a personal reader, scan for codes.
Post the codes.
Old 07-20-2019, 10:09 PM   #3
ssicarman
ssicarman's Avatar
Engine?
Codes?
Are you using a code reader/scan tool to try and erase the codes?
Add to ssicarman's Reputation
2006 Saturn Ion 2.2L flashing check engine light robbieholtz Ion Tech 13 05-11-2018 04:30 AM
2006 Saturn Vue 3.5 Check engine light shows P0113, P0135, P2253, P0135 IT_Architect Vue General 3 08-16-2017 03:56 PM
Check Engine Reset!!!! Roushy Vue Tech 14 06-20-2017 08:33 AM
Reset Engine Light dlacacres Vue Tech 8 01-04-2016 11:40 PM
Check Engine Light Reset Brian1234 Ion General 1 02-18-2015 03:57 AM
