Old 06-08-2019, 03:17 PM   #1
Red97sc2
Red97sc2 is on a distinguished road
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Default 2001 LW300 blower Motor issue
Long time member. Iíve had to move on to other makes of cars but still a Saturn FanÖ
The car in question = 2001 LW300 approx. 74k miles.
Itís my father in laws car and heís having a blower issue. It doesnít work.
Things he has done are: Tested the motor = OK, Resistor = replaced. Just today we removed the actual switch from the housing and cleaned up the contacts, used silicone grease on the contacts and STILL no blower.
I have a picture of the back end of the plug for reference. I have found some posts on here about ďjumpingĒ a couple of the wires to test the switch but I believe itís old enough that I canít find a wiring diagram for it to know which wire is which.
If jumping them is not a good thing to do maybe someone else has some ideas about what the issue could be. Everything is still taken apart so we have access to plugs and such.
Any help is greatly appreciated.
Thanks,
Paul
2008 Dodge Grand Caravan.
2008 Nissan Altima
1970 Mercury Cougar: 351C, 4spd. Classic for shows.
2005 Subaru Impreza
2003 Grand Marquis
Add to Red97sc2's Reputation
Rate the quality of this post and help Red97sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red97sc2 is offline   Reply With Quote
Old 06-08-2019, 06:49 PM   #2
Default Re: 2001 LW300 blower Motor issue
This wiring diagram should help. Checked for blown fuses?
Old 06-09-2019, 12:30 AM   #3
Red97sc2
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Fuses were checked initially but he's going to go over them and the blower motor resistor connections once more to make sure everything is nice and tight.
BTW: They are about 1.5 hours away from me so the replies might be slow to come but it is being worked on and we appreciate the help!
2008 Nissan Altima
2005 Subaru Impreza
2003 Grand Marquis
Old 06-09-2019, 11:57 AM   #4
ssicarman
ssicarman's Avatar
Verify that you have power to the blower motor.
Make sure that the ground for the blower motor is good, provide another ground and see if the blower runs.
There is a connector for the blower behind the radio that the ground wire likes to melt.
Add to ssicarman's Reputation
Old 07-02-2019, 08:06 PM   #5
Red97sc2
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Well, an update of sorts...
He does have power to the blower motor. He knows this due to the following situation:
He and his son in-law replaced the fuel pump (another thread about that) and once was all back together they turned it over and WOW, the blower, even though they were working on the fuel pump, came on and was working fine....for about a minute then stopped again.
Just today he buttoned up the center dash 100% and STILL no blower.
He was thinking about relays under the hood (but I think he's already done this) so we're kind of at a loss. Why, when working on something else, did the blower work for a short time. Could it possibly have something to do with disconnecting the battery?
Thanks again all!!
2008 Nissan Altima
2005 Subaru Impreza
2003 Grand Marquis
Old 07-02-2019, 08:44 PM   #6
Intermittent connection? Did you read post#4 (and use the wiring diagram)?
Blower motor issue mdbrill S-Series General 3 09-09-2018 01:58 AM
HELP...2001 L200 blower motor? 18IsTheMan L-Series Tech 3 11-06-2010 01:17 PM
Blower motor issue ruley73 S-Series General 5 08-19-2010 01:22 AM
Just replaced blower motor on 2001 LW300 Garciavision L-Series Tech 25 08-20-2009 02:16 PM
LW200-2003; Blower Motor Issue robinsonbybee L-Series Tech 0 01-26-2009 01:52 PM
