Old 10-27-2009, 07:10 PM   #1
sr20fd3st
sr20fd3st is on a distinguished road
Default 99 SW2, re-ocurring p0414 O2 sensor Code
Hey,
I need to pass emissions check. My check engine light has been one for a while because of the O2 heater circuit malfunction code.
I put in a new cat, and bought a new O2 sensor (Bosch direct fit plug) and the code ended up coming back, but not the light (yet). I know the code has to occur twice to throw the CEL, but the fact that there is 1 occurence in the computer is bugging me. Weird thing is it keeps coming back, but just the one. If I try to clear it while it's running it will erase it and then say 1 code remaining (the one I just erased). If I erase it while it's NOT running it will get rid of it all together, but then come back within 1 or 2 minutes of starting back up.
I dont understand how it is ALWAYS occuring just once, but after multiple starts and ignition cycles it wont occur a second time to throw the CEL.
Anything on this?
Thanks,
-Oliver
Add to sr20fd3st's Reputation
Rate the quality of this post and help sr20fd3st reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sr20fd3st is offline   Reply With Quote
Old 10-27-2009, 07:39 PM   #2
Default Re: 99 SW2, re-ocurring p0414 O2 sensor Code
DTC P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
Are you certain that your P0414 error code is what you saw displayed and attempting a correction but to the wrong parts? The above OBD II DTC is from our How-to ibrary and we here at Saturnfans tend to compare DTC's against references that are as accurate as posted by trusted members and not from Googling that can mislead with misinformation sometimes.
VCX NANO
Old 10-27-2009, 11:58 PM   #3
sr20fd3st
Default
woops. meant p0141. sorry. light came on by the way. besides the new sensor what else could cause this?
Old 10-28-2009, 12:18 AM   #4
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
Ok, that's better. This is for the rear O2 sensor with a heater circuit problem.
VCX NANO
Old 10-28-2009, 11:15 AM   #5
sr20fd3st
Made a new thread with a proper code in the title.
http://www.saturnfans.com/forums/sho...07#post1534207
97 SW2 code p0134 GQROD S-Series Tech 18 06-27-2009 01:01 PM
95 SW2: Help with Code 19 David Grigor S-Series Tech 3 11-01-2008 06:47 PM
MAP sensor location on a 95 SW2 SeanD S-Series Tech 2 08-26-2008 01:05 PM
P0414 Failed Emission- NEED HELP!! azure S-Series Tech 0 12-07-2005 11:52 AM
98 SW2 Engine Code Urbanrover S-Series Tech 1 04-05-2005 11:55 PM
