Closed Thread
Old 09-17-2004, 01:30 PM   #1
David 93 SL2m
David 93 SL2m's Avatar
2007 ION-3 Sedan
Wrench Wolfman's Guide for Diagnosing the Radiator Cooling Fan
Does your radiator cooling fan appear to never come on?
First, check the fuse for the radiator cooling fan.
Second, check the relay for the radiator cooling fan.
Third, follow Wolfman's guide:
  1. Disconnect the ECTS (Engine Coolant Temperature Sensor) connector.
  2. Connect the two contacts inside the connector together with the two ends of a small paper clip.
  3. Then turn on the car (either start the engine or turn the key to "RUN" without starting the engine).
Okay, is the radiator fan running now?
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 04-15-2005, 07:22 AM   #2
David 93 SL2m
2007 ION-3 Sedan
Post Re: Wolfman's Guide for Diagnosing the Radiator Cooling Fan
I forgot to mention that turning the air conditioner on while the engine is running should cause the radiator cooling fan to start running.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-15-2005, 05:30 PM   #3
texlnghorn
texlnghorn is on a distinguished road
1992 SL
Default Re: Wolfman's Guide for Diagnosing the Radiator Cooling Fan
Also jumping terminals A and B on an OBD 1 ALDL will start the radiator cooling fan.
Add to texlnghorn's Reputation
Rate the quality of this post and help texlnghorn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
texlnghorn is offline
Old 06-11-2005, 01:12 PM   #4
Bill Z
Bill Z is on a distinguished road
My Saturn is a 99 4 door with 2 OHC. The radiator fan turns on with the AC. Without the AC the car over heats at stop lights.
I used a scanning tool and the 2 wire temp sensor seems to be telling the ECM what the temp is. I can see it going from 80 to 193 degrees over about 10 minutes of idling in the garage. The dash temp gauge only shows 1/4 and never more.
I disconnected the 2 wire sending unit and the temp on the ECM went to something like -40. I reconnected and it displayed a temp. I disconnected the one wire sending unit and the temp gague on the dasy went to zero.
Since the AC makes the fan work, the fan doesn't have a problem. The 30 amp fuse is good. The AC relay is working. The fan relay is working. By the way, I swapped the AC and fan relay just to see. No change.
So, what makes the fan turn on with out the AC on? Where do I check next?
What did I miss?
Add to Bill Z's Reputation
Rate the quality of this post and help Bill Z reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Z is offline
Old 06-13-2005, 01:36 AM   #5
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
the fan relay is directly controlled by the PCM and is only controlled by the PCM.
the PCM will turn on the fan if it sees:
the PCM is in diagnostic mode
-OR-
the ECT reads above appox. 220 F
AND
-OR-
the A/C request is on(or for appox. 40 seconds after the A/C is turned off)
AND
if the ECT never read above 193 F it is most likely bad. -40 is the standard minimum reading for all temperator sensors that i know of.
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline
Old 07-06-2005, 05:13 PM   #6
93goldsl2
93goldsl2 is on a distinguished road
1993 SL2
Don't overlook the possibility of a bad ground for the fan motor. One side of the fan motor plug should be +12V with AC on or at 'hot' temperature (decided by PCM via ECTS I guess) and the other should be grounded. For me, for some reason there was no path to ground. I ran a jumper wire (make sure you use similar size wire to what's on there...) to the body and it fixed my problem.
Add to 93goldsl2's Reputation
Rate the quality of this post and help 93goldsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93goldsl2 is offline
Old 09-23-2005, 07:03 AM   #7
briknope
briknope is on a distinguished road
Dizzy Re: Wolfman's Guide for Diagnosing the Radiator Cooling Fan
I get no fan operation whatsoever even with the ac switched on, and the car starts to overheat while it is ideling. I noticed this problem when the A/C started to blow hot. When the car is moving, the Air Conditioning blows cold again. I wiggled wires going to the fan, while the AC was switched on, and still nothing. This has probably been this way for quite some time, as my wife drives it most of the time, and doesn't tell me much. Oh I forgot to mention, this is on a 96 SL1. Can I assume that the fan motor is a goner? Fuses and relays seem fine, I switched the AC relay with the Fan relay (they appear to be the same according to the numbers on both) and got the same result. I hate to start throwing parts at the car hoping to fix it like coolant temp sensor and everything else that "could" be bad. I don't think its the sensor, seeing as how the fan doesn't work with the air on either. I get no check engine lights or "service" light. Can I assume that there is nothing wring with the computer?
Hope someone can enlighten me on this one. I'm betting on the fan motor, unless someone can advise differently.
Add to briknope's Reputation
Rate the quality of this post and help briknope reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
briknope is offline
Old 10-02-2005, 03:02 PM   #8
jfstringer
jfstringer is on a distinguished road
briknope, I have the same problem you have, but unfortunately I'm not any closer to figuring it out.
Mine is a '98 SL1 with standard transmission and about 107K miles. I noticed today that when starting a cold engine and letting the car sit stationary with the A/C on, the cooling fan runs for a minute or two, and the A/C works fine. After the engine begins to heat up, the cooling fan and A/C both cut off. The cooling fan doesn't come back on, but the A/C switches on and off a few times for shorter durations each successive time until finally it stops completely unless I get the car above 20 to 30 miles per hour. At first I thought the computer simply was cutting the A/C off as the engine got too hot, but as long as the car is moving over 20mph or so, the A/C will come on regardless of how hot the engine is. Also the first time the A/C cuts out, the temp gauge shows the needle just under the 1/4 mark. It seems to me that the A/C cuts off because the fan cuts off and has nothing to do with the engine temp.
I, too, have checked fuses, tried "wiggling wires," cleaning electrical connections, and swapping relays to no avail. I'm going to pull the fan/motor assembly out in a few minutes to test it directly. I'll let you know what I find out. If you (or anyone else) come up with anything, please let me know. Thanks!
Add to jfstringer's Reputation
Rate the quality of this post and help jfstringer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jfstringer is offline
Old 10-02-2005, 04:09 PM   #9
Rogn38
Rogn38 is on a distinguished road
Rogn38's Avatar
1992 SL2
When I bought my 92'SL2 from a friend of mine, he toldme that the cooling fan does not come on when the engine is hot, so he wired the fan directly to a switch.
Since reading this fourm, I tested the ECTS as described, using a paper clip, but the fan still failed to come on.
Now I know the fan is ok, as it works via the installed manual switch.
Does anyone have any other suggestions as to how to get the cooling fan operating as designed?
Add to Rogn38's Reputation
Rate the quality of this post and help Rogn38 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rogn38 is offline
Closed Thread
Wolfman's manual radiator fan switch diazdavenator S-Series Mods 18 02-03-2010 12:36 AM
Radiator Cooling Fan not working Zeroherokid S-Series Tech 14 01-17-2008 01:17 AM
Radiator cooling fan relay?? duganator S-Series Tech 3 09-12-2007 01:49 PM
Radiator Cooling Fan Glasact L-Series Tech 4 06-04-2007 02:23 PM
Refrigerant and Radiator Cooling Fan? jilly S-Series General 5 10-07-2005 09:37 PM
