Go Back   SaturnFans.com Forums > Site Information > Community Center > Suggestion Box
Old 11-13-2019, 08:34 PM   #1
Default For those clueless about soldering....
I've used a simple soldering technique introduced years ago. A very small piece of thin solder similar to tiny bandages for small cuts about 3/8" X 1" wrapped around twisted bare (clean) wires and a match was useful for electrical soldering away from an ac outlet and soldering iron. Fast forward and we have portable butane torches with a soldering tip for complete portability in field repairs. This presumes most people are already familiar with basic soldering techniques. For the truly clueless and those not wanting to learn soldering, a new product may help and provide virtually a professional appearance after some trial and error period of experimenting. Be warned though. Soldering in any form still requires some semblance of clean copper wires for solder and rosin to flow and coat each bare wire of a twisted set before solder can adhere to provide electrical and mechanical strength.
This appeared on facebook and here's a link; https://afrui.com/collections/hot-de...Y-D3-JwFGJMAZU. The video should convince anyone that virtually everyone should be able to solder wires together and insulate the connection with shrink tubing. For auto repairs and tight spaces, this may be one of the best solutions for fast and easy soldering without needing skills other than flicking a Bic or striking a match. For those using fire, beware of nearby plastic rugs catching on fire. No torch is needed. This product appears to use a lower temperature melting point solder with rosin shaped into a small bushing covered in see thru shrink tubing.
Old 11-22-2019, 04:06 PM   #2
Default Re: For those clueless about soldering....
Interesting.
May want to repost this in the S-series and other more general / model specific forums for exposure or post a link to this thread.
I note they recommend using a heat gun, no not as precise as a soldering iron. I suppose I would use a damp towel and aluminum foil to insulate things I don't' want to heat up.
Old 11-25-2019, 09:15 PM   #3
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
Originally Posted by alordofchaos View Post
Interesting.
the heat guns they're talking about, are specific to soldering, and have a very small output hole size.
they're actually used quite a bit by electronics repairmen and assemblers as well.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 11-25-2019, 09:18 PM   #4
SL2 Ride
2005 ION-3 Sedan
i've been a fan of soldering wires when i'm splicing something, particularly under the hood of a car. if I have good access to the wire, i'll sometimes put a coating of silicone over the soldered area instead of tape to help keep it from corroding.
Old 11-27-2019, 01:52 AM   #5
TomM96
Soldering, adhesive joints and good paint coating adhesion all require a clean surface. The acid flux or rosin flux are both cleaning agents ... best to start with a very clean/dry metal surface.
cleanliness is important for quality welds/brazing .... but in those cases the applied heat assists driving off garbage. Some 'maintenance' welding can be done on dirty/greasy surfaces, but the joint would not meet many quality specifications, because the garbage becomes part of the joint.
It helps to remove the residue of rosin flux after soldering (wait until cool), before sealing. I also oft use silicone RTV as a sealant, then coat with vinyl electrical tape for abrasion resistance.
Add to TomM96's Reputation
Old 11-27-2019, 01:35 PM   #6
That's a great idea! What do you use, and do you find that your silicone dries out in the container between uses?
Nothing worse than opening up a tube or tin of something, only to find that it has all dried out . . . and you end up making a trip to the store
Old 12-25-2019, 01:59 AM   #7
velocast
velocast has a spectacular aura aboutvelocast has a spectacular aura aboutvelocast has a spectacular aura about
Thanks for the INFO
I just got from Harbor Freight a Butane Mini Torch, from Walmart a can of Refill Butane, and from eBay Heat Shrink Wire Connectors.
In the center of the connector there is a low temperature solder sleeve that will melt down when heat is applied. In the connector extreme sides are melt adhesive compound that will seal waterproof the wires.
It all depends how good you apply! Make sure to start from the center. When you see the tin sleeve is melting down go to the rest of the connector. Heat will spread to the sides shrinking the tube.
IT IS WAY QUICKER THAN USING AN IRON SOLDER
Add to velocast's Reputation
Rate the quality of this post and help velocast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velocast is offline   Reply With Quote
Soldering iron for automotive use RobertGary1 S-Series Tech 24 01-08-2013 10:57 AM
Radiator tank crack fix with soldering iron tgferg67global S-Series Tech 15 04-12-2011 01:58 PM
things not to do when soldering diff pin pascal_ladale S-Series Tech 9 07-19-2007 09:49 PM
Can anyone help me clueless cheverie S-Series General 8 07-06-2006 04:03 PM
Clueless ION Owner CaliLime Ion General 10 05-07-2004 11:55 AM
