Old 03-23-2017, 03:01 PM   #1
macantley
macantley is on a distinguished road
Default new to me, 2006 saturn vue 102k miles horrible grinding in rear when AWD is engaged
the vehicle is nice and quiet during normal driving, When the AWD is kicked in it sounds as if the rear wheels are dragging the rear bumper or a fender liner, the AWD is working, maybe slipping alittle bit though but all 4 wheels do seem to be spinning. I've never seen or heard anything this crazy when AWD kicks in.
I did a search and it seems there's several people with this noise and there's a youtube video of a guy driving his saturn vue in the snow and its making the same noise as mine. I'm guessing im going to have to replace the rear differential but was curious if there's any simpler fix. as loud as this problem is i dont see a simple fluid change being the solution. just curious if anyone has any recommendations.
any and all help is appreciated.
Add to macantley's Reputation
Rate the quality of this post and help macantley reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macantley is offline   Reply With Quote
Old 03-23-2017, 04:06 PM   #2
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
2005 VUE 3.5L
Default Re: new to me, 2006 saturn vue 102k miles horrible grinding in rear when AWD is engag
Check the carrier bearing and/or change the lubricant.. More experienced SF's will chime in.
Add to JefferyC's Reputation
Rate the quality of this post and help JefferyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JefferyC is offline   Reply With Quote
Old 03-23-2017, 08:33 PM   #3
macantley
Carrier bearing looks great, no play in the driveshaft anywhere, however i can grab either axle in the rear and shake it up and down quite a bit at the rear differential, more play there than any vehicle i've ever seen, I've had alot of AWD vehicles and rear wheel with independent suspension vehicles and never have i seen so much play up and down where the axle stubs go into the differential.
matthew
Old 03-23-2017, 09:50 PM   #4
billysvue
2005 VUE 2.2L
matthew
THat sounds like your problem right there. SOunds like the RDU needs serious service/RnR/replacement or just remove the driveshaft and make it FWD.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 03-24-2017, 09:23 AM   #5
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
I had a groan in my RDM when the AWD was engaged when I bought my Vue. Doing the fluid change solved the noise. Before you go throwing parts or deleting parts, you may want to have that fluid serviced.
2001 L-200 2.2l
DOB: 05/08/01 Owned: 07/01/07 to 10/30/18
2006 Vue 3.5L AWD Mileage: 145,000
DOB: 08/24/05 Date Acquired: 12/15/06
2019 GMC Acadia (aka Saturn Outlook)
Add to flyingj's Reputation
Rate the quality of this post and help flyingj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyingj is offline   Reply With Quote
Old 03-24-2017, 12:02 PM   #6
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Change the fluid.... with the Versatrak fluid.... and could your rear C/V joints be bad on the inside of the axle?
John.
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
Old 06-24-2017, 05:04 AM   #7
chillin05VUE
chillin05VUE is on a distinguished road
chillin05VUE's Avatar
2005 VUE 3.5L
Mine did that when I first got it. Come to find out, my rdm was shot. Saturn replaced it and the noise was gone.
"Remember, if the women don't find you handsome, they should at least find you handy" -Red Green
2005 VUE V6 AWD
Add to chillin05VUE's Reputation
Rate the quality of this post and help chillin05VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chillin05VUE is offline   Reply With Quote
Old 09-02-2019, 05:20 PM   #8
07AWDV6Redline
07AWDV6Redline is on a distinguished road
2007 VUE Red Line
So what was the final out come with the noise mine does the same thing
Add to 07AWDV6Redline's Reputation
Rate the quality of this post and help 07AWDV6Redline reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
07AWDV6Redline is offline   Reply With Quote
Replaced rear driver bearing hub. Saturn Vue 2006 Superflywimpy Vue Tech 14 06-12-2016 08:13 PM
2006 Saturn Vue red line transmission fluid change at 222,000 miles???? cristian1090 Vue Tech 4 01-21-2016 07:16 PM
Saturn Ion (2006) rear door wont latch iratic Support Forum for Canadian Saturn Owners 1 01-02-2012 09:01 PM
Good buy? 2002 Saturn SL1 102k miles... intercessor S-Series General 14 05-31-2008 01:04 AM
99 SL1 102K Power Cuts Out? HighwaySL1 S-Series General 2 11-19-2005 09:52 PM
