Old 04-13-2015, 07:27 PM   #1
heyjustchill
heyjustchill is on a distinguished road
Default Replacing PCM
Hey i have Saturn 1999 SL1 and i am a 100% sure the pcm is at fault. I was wondering if i could use this to read the pcm and then flash that onto a new pcm. ebay.com/itm/New-MPPS-V13-02-Chip-Tuning-K-CAN-Flasher-Cable-ECU-Programming-Tool-/121527769134?hash=item1c4b9e982e&item=121527769134 &vxp=mtr
BTW this is my pcm: s4.postimg.org/5mq5vqfcd/Full_Size_Render.jpg
Also as a side note its kinda of weird that the pcm is for 97 Saturn and not a 99.
Thanks for any advice or help
Add to heyjustchill's Reputation
Rate the quality of this post and help heyjustchill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
heyjustchill is offline   Reply With Quote
Old 04-13-2015, 07:46 PM   #2
Default Re: Replacing PCM
You need to find a 99 SOHC Auto PCM with the same options you have. See link for options to match. Options MUST match or you get to have the 99 box reflashed by the dealer.
http://www.saturnfans.com/photos/sho...ions/cat/12963
RKE means electric door locks.
Old 04-13-2015, 08:03 PM   #3
heyjustchill
So i can't just read my current pcm and flash onto this ebay.com/itm/97-SATURN-S-M-T-ECM-21023775-21008668-See-item-description-/181419843251?hash=item2a3d771eb3&vxp=mtr using the above cable?
Old 04-13-2015, 08:13 PM   #4
No. The first number on that label is the actual flash code part number and the 2nd is the hardware part number and it is for a earlier PCM(96 - 97). Not sure why you think it is defective but I would not hold out much hope for it functioning correctly with a 99 SOHC with auto trans.
Old 04-13-2015, 08:26 PM   #5
heyjustchill
Well the current PCM is installed is a 97 from my understanding which seems rly weird.
Old 04-13-2015, 08:32 PM   #6
Try using a real keyboard, or edit carefully.
A 96-97 PCM hardware is not compatible with a 99 car. I have no idea exactly which flash code is in there but unless it is actually for a 99 it is not going to work.
Replacing DEX III with ATF+4 1996SL11.9L S-Series Tech 8 09-05-2012 07:22 AM
Need help replacing a bad ECM patpatt L-Series Tech 8 03-28-2011 09:06 PM
replacing front brake pads on 2002 L-200 requires replacing rotors? UserName L-Series General 12 12-29-2004 01:28 PM
Replacing my '92 SL2..... Tuanies S-Series General 16 03-31-2004 02:41 AM
Replacing SL1 ECU viperman7116 S-Series General 6 12-26-2003 12:23 PM
