Old 08-26-2010, 10:54 AM   #1
Thrashplayhere
Thrashplayhere is on a distinguished road
Default SL2 Coolant Issue
I have a 2000 Saturn SL2 with a coolant issue. 2 days ago my low coolant level light came on and I had to add water three times just to get home from work. I dropped off my car and my mechanic replaced the water pump, 2 main radiator hoses, serpentine belt and added new coolant.
Yesterday, I'm on my way home from work, I was sitting at a red light and the traffic was backed up pretty bad. I start seeing steam come out from under the hood about where the coolant reservoir is. It as iff the coolant start to boil and then slowly leak out.I had this issue once before about 7-8 months ago and my mechanic said my fan wasn't coming on and he replaced the fan motor. Obviously, it's something more than the parts I've already had replaced.
I want to assume it's the thermostat (which I can buy and replace myself) but, I wanted to see what you guys think it could be.
Thanks in advance!
Add to Thrashplayhere's Reputation
Rate the quality of this post and help Thrashplayhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thrashplayhere is offline   Reply With Quote
Old 08-26-2010, 11:19 AM   #2
Default Re: SL2 Coolant Issue
Has the Engine Coolant Temperature Sensor (ECTS) ever been replaced?
It's a $10-15 part that tells your PCM (computer) the engine temp - the original resin-tipped one tended to crack and give low readings to the PCM. As a result, the temp gauge would read low (typically around 1/4 scale), the engine runs a little rich (can cause stalling or hard starts/restarts) and... the PCM does not turn the fan on because it thinks the engine is still cold.
The How To library has both the How To as well as links to richpin's videos on youtube showing how to find it and replace it.
The other likely possiblity is that the reservoir cap is no longer holding pressure. you could try a new or junkyard one, they are pretty cheap.
Welcome to saturnfans... sit a spell. soon, you will be saying "holy crap, there is a lot of good info here"
Old 08-26-2010, 12:03 PM   #3
DonP
Welcome. As noted above:
The #1 thing to check is the ECTS, especially if the temp gauge was not approaching the red zone when it boiled over. Replace it if it is the old type, and check toe connector for possible corrosion taht coudl cause false readings. See the first few sticky threads in the How-to Library forum for more details.
The #2 thing to check is the coolant reservoir cap. It might not be on tight or might not be holding pressure resulting in a low boiling point of the coolant.
S-car T-stats usually fail open if installed correctly so that is not a likely issue.
Weak coolant can result in low boiling point, but not likely if your mechanic was any good.
Add to DonP's Reputation
Rate the quality of this post and help DonP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-26-2010, 12:31 PM   #4
Good point - The OP mentions having to add water three times on the way home.
A 2000 should have had the antifreeze changed at least once and a lot of shops use 50/50 premix these days. So the antifreeze could have become a mostly water mix at the time he took it to the shop.
Next, the mechanic does his replacements - and as we know, there is about a quart of the old left over in the heater core area. So if the mechanic filled with 50/50 premix, it is likely that the actual concentration is lower.
And we have another unknown, altitude... all the charts are based on sea-level
Old 08-26-2010, 04:35 PM   #5
Thrashplayhere
I'll try the ECTS first. Never heard of it until now. <fingers crossed> I'll update you guys and let you know how it works out.
Thanks!!!!
Old 08-28-2010, 04:31 PM   #6
Thrashplayhere
Replaced my ECTS and coolant reservoir cap today, didn't seem like it was working at first but then, I forgot I had to disconnect the battery and allow the system and the sensor to reset. Reconnected and could literally hear the car systems resetting. Started up the car and let it idle for about 20 minutes in the driveway. Then, drove it around for about 15 minutes with the AC on high, Got back to the house and let it sit idle for about another 15 - 20 minutes...temp needle stayed pretty much right in the middle as it should.
Once I replaced the parts I refilled the coolant reservoir with water just in case the sensor didn't fix anything. Now, I need to figure out the best way to drain the water and replace it with real coolant...
But, THANKS a TON for your suggestions. It's hard to believe that such a major problem could be so easily repaired without a mechanic and for very little money.
I appreciate you guys and this site!!!!!!!!!!!!!
Coolant issue SaturnSL2Guy S-Series General 7 05-17-2010 07:48 PM
REALLY frustrating coolant issue aimeesnyder Ion Tech 5 03-03-2010 06:34 PM
Coolant Issue deacon20 S-Series Tech 5 02-20-2010 02:06 AM
Coolant issue tempomental S-Series Tech 26 02-12-2010 05:13 PM
Another Coolant Issue Matt4572 S-Series Tech 2 12-30-2009 04:18 PM
