Old 07-23-2010, 01:55 AM   #1
starnes892
starnes892 is on a distinguished road
Default ignition coils? anything better then stock?
i was doing some looking and found some accel coils and found that most v6 gm engine coils will work with mod. does the stock coil drop volts after it gets rusty?
I have installed low ohm wires. (obx)
Add to starnes892's Reputation
Rate the quality of this post and help starnes892 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
starnes892 is offline   Reply With Quote
Old 07-23-2010, 01:57 AM   #2
bbarbulo
bbarbulo is on a distinguished road
Default Re: ignition coils? anything better then stock?
it's generally agreed that the BEST setup is the original stuff. even the OBX wires take away from system reliability. same goes for ignition coils.
Add to bbarbulo's Reputation
Rate the quality of this post and help bbarbulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbarbulo is offline   Reply With Quote
Old 07-23-2010, 10:18 AM   #3
The aftermarket coils are all junk, use good condition stock OEM. You can use Magnecore wires if you want but other than the Magnecor wires stay with the regular carbon fiber wires.
Old 07-23-2010, 10:58 AM   #4
starnes892
from what i seen the obx wires make a big difference with how my car runs e85. and i was looking for a better coil but i havnt talk to anyone personally but i have read that replacing the coils with the ones out of a gm v6 work better the stock but would like more input on this.
Old 07-23-2010, 12:09 PM   #5
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
I tried ACCEL coils. One of them failed.
I went back to a stock setup I pulled from a wrecker car... problem free.
Don't waste your time.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 07-23-2010, 12:25 PM   #6
Ah, you didn't mention the E85 before
You mean like this?
http://www.saturnfans.com/forums/sho...d.php?t=156186
I don't know if they "work better" or are just less prone to corroding.
Old 07-23-2010, 12:58 PM   #7
starnes892
with the accel did have any improvements? and alordofchaos thats what i was talking about they are a different type because they use them on the supercharged engines so i figured they would be better then the stock saturn coils
Ignition Coils.... oakraiders24 S-Series Tech 5 03-06-2007 09:58 PM
Ignition Coils Steven62387 S-Series General 3 08-02-2006 01:40 AM
Ignition Coils Batman87 S-Series Tech 4 04-24-2006 09:46 PM
Ignition coils Aldiaz2331 Miscellaneous Tech 4 10-18-2003 10:49 PM
new ignition coils robk Mods and Performance 4 02-21-2002 06:38 PM
