Old 03-18-2008, 10:34 AM   #1
TXSaturn02
TXSaturn02's Avatar
Default Gas Pedal
Every once in a while, my gas pedal acts like it is stuck in the "resting" position. I have to give it a little extra effort to move it from where it rests. This will go on for a while, but eventually be back to normal. Anyone else experience this quirk? This happens maybe every few months and lasts for a day or two at most depending on how much I'm driving and having to engage the clutch/gas.
As of 07/25/18: 51,495 Miles
Old 03-18-2008, 10:50 AM   #2
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Default Re: Gas Pedal
Clean your throttle body and you'll notice a HUGE improvement
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
Add to rc1488's Reputation
Rate the quality of this post and help rc1488 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rc1488 is offline   Reply With Quote
Old 03-18-2008, 10:54 AM   #3
gordoloff
gordoloff is on a distinguished road
gordoloff's Avatar
Really? I should do the same because I feel it on the odd occassion myself to a lesser degree than his by the sounds of it. I recently joined and changed my ectc for a brass one and cleaned my EGR valve and what a difference in gas mileage, she's back baby! New plugs, wires, and air filter too. Haven't cleaned the throttle body yet though. I did buy the gasket so i can take it right off to do it and have the new gasket to replace the old on hand. 95 SL1 I've had for 4 years and have hardly done a thing until recently, like I said, it still had the cracked resin ECTS! Anything else easy I should do that I have not?.
1995 Saturn SL1 Sohc 311,000kms
Add to gordoloff's Reputation
Rate the quality of this post and help gordoloff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gordoloff is offline   Reply With Quote
Old 03-18-2008, 10:55 AM   #4
TXSaturn02
TXSaturn02's Avatar
Throttle body effects the PEDAL? But it has been doing this since it was almost new and only for a while and goes away - as if there is stickum or something on the pedal itself.... I suppose if I understood how the throttle body is connected to the hip bone....
Old 03-18-2008, 11:09 AM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
yup, sticky gas pedal usually = sticky throttlebody. They are connected via the throttle cable, which is pretty stiff (has to be). Pop your hood & play with the quarter-circle shaped cable attachment/guide on the throttlebody. If it sticks at all when you push down on it, then there ya go, time to clean the throttlebody.
(pic shows unhooking the throttle cable, just push down without messing with the cable to check for stickiness)
http://www.saturnseries.net/DIY%20Gu...gh%20clean.htm
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 03-18-2008, 11:14 AM   #6
TXSaturn02
TXSaturn02's Avatar
Thanks guys. I will tackle this when that pedal becomes bigger nuisance.
Old 03-18-2008, 11:19 AM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
you also have the option of doing a quick-clean without removing the throttlebody.
http://www.saturnseries.net/DIY%20Gu...ck%20clean.htm
which doesn't help with IAC issues much (but it doesn't sound like you're having), but does help with sticky gas pedal issues.
Old 03-18-2008, 11:37 AM   #8
rc1488
rc1488's Avatar
Yupps. Heres a list:
http://www.saturnfans.com/forums/sho...d.php?t=114730
Dont wait to long. If theres enough carbon for a sticky pedal, its not long before your passages get clogged and and the IAC to stick
Do a good full cleaning instead
Old 03-18-2008, 02:56 PM   #9
alshoe
alshoe is on a distinguished road
2002 L-Series 3.0L Sedan
Thanks for the post. We bought our son a used 2002 SL2, auto trans, last September. Noticed this same charactaristic. Will take the experts advice.
This charactaristic has not occured on my 1993 SC2, manual trans.
alshoe
Add to alshoe's Reputation
Rate the quality of this post and help alshoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alshoe is offline   Reply With Quote
gas pedal to the floor Toms XR3 Astra General 7 04-16-2009 03:36 PM
08 Arua brake pedal closer then gas pedal ralphtrent Aura General 11 03-04-2008 05:36 PM
Installing new pedal covers, can't remove gas pedal strongboy2005 S-Series Tech 4 12-09-2006 06:02 PM
rl gas pedal vs non-rl gord888 Ion General 13 06-29-2006 07:12 PM
Gas Pedal DHOOP S-Series Tech 4 06-18-2006 01:53 PM
