Old 11-08-2020, 05:53 PM   #1
Homecoming1999
Homecoming1999 is just really niceHomecoming1999 is just really niceHomecoming1999 is just really niceHomecoming1999 is just really nice
Default Power windows slow?....Try this tip..!
Hey guys, I am sure a lot of us experience slow windows going up and down at some point, especially the ones we do not use as much....rear for example. I was told by my mechanic to buy some good white lithium grease in a spray can and spray it in the tracks of where the windows go up and down, the little groove where the glass sits in on both sides of the window. This made a huge difference for me. Once you raise and lower the window a few times and "work the grease in" you can audibly hear the difference in the power window motor. They also go up and down much faster.
Cheers all
Jason
Homecoming1999 is offline   Reply With Quote
Old 11-08-2020, 07:59 PM   #2
454cid
Default Re: Power windows slow?....Try this tip..!
Cheers all
Jason
Maybe I'll give that a shot. My passenger side front.... the one I use most often... is slow.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
Old 11-09-2020, 09:51 AM   #3
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
On the first gen Miatas, this is quite common. The fix for them was to clean the guide out as best you could with alcohol and qtips, then they would use Honda Shin-Etsu grease. in the rails.
Its really just a silicone grease, so probably anything like that would do
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 11-09-2020, 11:00 AM   #4
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
I have been using silicone spray every once in a while and itís been working for me.
It's GOOD to have a spare!
termite is offline   Reply With Quote
Old 11-11-2020, 09:23 AM   #5
td1238
td1238 will become famous soon enoughtd1238 will become famous soon enough
Cheers all
Jason
I pour Dot 5 silicone brake fluid down the tracks. I have never used lithium or petroleum type greases because I was unsure as to how they'd affect the rubber. As in your experience, however, the lubrication makes operating both electric and crank windows a breeze. Also, wiping Dot 5 or ru-glide on the door gaskets makes for a quieter and less squeeeeeeeky ride.
td1238 is offline   Reply With Quote
Old 11-11-2020, 04:47 PM   #6
C52
C52 is a jewel in the roughC52 is a jewel in the roughC52 is a jewel in the rough
1997 SW2
My power windows will not even go down unless I assist by pulling down on the glass with my hand. They go back up fine. I tried cleaning the tracks with alcohol and Q-tips and they seemed to work a bit better, but applying a thick PB blaster white spray lithium grease to the track brought my windows to a stop once again. I notice my glass shifts to one side when I try to open the window, I suspect some other problem inside of the door.
C52 is offline   Reply With Quote
Old 11-11-2020, 05:03 PM   #7
td1238
I know that others here have indicated success with petroleum type greases such as litheum, but you really don't want to use a petroleum grease on rubber. It both swells and damages the rubber, and getting the rubber to un-swell takes a very long time. I once used it on brake caliper pins, and the rubber bushings swelled and seized the pins. This made for all sorts of problems.
What you really want is a silicone grease or oil, and without a petroleum carrier such as kerosene. Silicone grease (dielectric grease) can be rubbed into the rubber window channels, but it won't get down into the lower part much. Go to NAPA and buy yourself some Dot 5 silicone brake fluid. With a v shaped piece of cardboard aimed into the window channel, trickle a bit of fluid down the track. Operate the window a few times to distribute. You'll have to clean excess off the glass, but eventually that goes away.
If your rubber tracks are swollen, you're going to have to wait a long time for them to de-swell, though silicone oil might help things. Hopefully other damage wasn't done.
Old 11-11-2020, 07:48 PM   #8
toggenburg
toggenburg's Avatar
Why all the bother to put something DOWN the channel?
All I have ever done on any car is to lower the glass, then use spray silicone with one of those tubes attached to the nozzle, spray both tracks ABOVE the sash, then raise the glass back up into the newly sprayed upper channels. Works every time and for like a year.
Old 11-11-2020, 07:48 PM   #9
Waiex191
Waiex191's Avatar
When I got my '98 the driver's window was very slow. I used silicone lube on the tracks and it improved for a while. Ultimately I had to replace the motor and while it was apart I cleaned and lubed the whole regulator mechanism. It works a lot better now.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 11-11-2020, 11:06 PM   #10
454cid
Dot 5 brake fluid is something I never would have thought of.
I really need to shop for a new can of silicone spray. The last stuff I bought is garbage. Whatever the carrier is, it fades plastic. I've got light spots on the plastic on my Saturn and my truck because of it.
1999 Chevy K3500
Slow defective reverse gear and power windows seem very confused - 2000 SW2 Dccc S-Series Tech 15 07-05-2013 07:27 AM
Manual Power Locks/Windows swap to Powered Locks/Windows/Keyless Entry Dreamimage S-Series Mods 20 12-03-2012 12:14 PM
slow windows branch99 S-Series Tech 1 07-19-2008 02:04 PM
manual windows to power windows swap mushusdad S-Series General 3 02-04-2008 05:08 PM
Manual windows to power windows M.Nguyen S-Series Tech 1 06-04-2004 08:25 AM
