#1 |
![]() Join Date: Oct 2020
I have an 07 Saturn Vue with a 2.2-liter engine that has 147000 miles. The engine runs great but every time I place the shifter in Reverse the idle drops and the engine finally stalls. This does not happen in drive or any other available positions. The car idles around 1200 RPM in park and drops to 1000 RPM when placed in drive. When placed in Reverse the idle drops to around 400-500 RPM and the engine stalls. I have replaced the throttle body, ECM, MAP sensor, and temperature sensor but no change. Does anyone have any suggestions?
#2 |
![]() ![]() ![]() ![]() Join Date: May 2008
2006 VUE Red Line
Check all your engine grounds for a break. I had something similar to this happen on an old Grand AM I once owned. It idled fine but once placed into drive it would just die. Tracked it down when pulling on the wire harness while idling and it died, the ground wire was broken making an intermittent connection. Fixed that and it ran like a champ.
Not saying this is your issue but something to look at.
.................................................. Saturn Vue: The 250 HP tupperware |
Bookmarks |
SL2 Engine dies!! | SL2nf150 | S-Series Tech | 29 | 11-24-2013 12:58 AM |
02 vue 2.2 5sp dies when brakes are pressed and when put in reverse. | reinhart0901 | Vue Tech | 2 | 11-15-2013 11:15 AM |
93 SL2 automatic dies going from reverse to drive quickly. | Crasoum | S-Series Tech | 0 | 09-16-2008 12:38 PM |
engine dies | allen57 | S-Series Tech | 13 | 09-16-2007 10:54 AM |
Hard kick when going into Reverse, then dies? | Yokozuna | S-Series Tech | 13 | 07-16-2002 08:40 AM |
