Old 09-15-2018, 08:31 PM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Engine Lacks Power HELP!
I drove 20 miles today and went to multiple places but now I am having issues with my engine. I have a 95 SL2 Automatic. Heres what happens: I start the engine, it starts and idles normally. I put it in drive and still idles normal but when I step on gas it does nothing, I floor the pedal even and it takes almost 10 seconds until the engine responds and gains power. Once I am at speed it can stay at speed, but when I need to go from a stop or if I remove foot from gas then apply it again to gain speed it takes several seconds for engine to respond. I did not find any vacuum leaks or lose connections, and the battery and alternator voltage is within normal limit.
What could be the problem?
07/2018-PRESENT 1995 SL2
12/2009-PRESENT 1994 SL1 (FOR SALE!)
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 09-15-2018, 08:56 PM   #2
Default Re: Engine Lacks Power HELP!
"...when I step on gas it does nothing,..."
Literally "nothing"? No change in sound or rpm, no misfire vibration, not spitting into the intake or farting into the exhaust? Have you tried opening the throttle by hand out at the TB?
Take compression readings, it is so easy to do and can be very telling. Put a vacuum gauge on it and verify vac goes towards zero when you open the throttle fully. Take the O2 sensor out and see if relieving back-pressure even that much makes a noticeable difference.
Add to billr's Reputation
Old 09-15-2018, 09:25 PM   #3
StrnWolf
1994 SL1
Well now it is having an issue with idle, it sounds a little rough. When I apply gas in PARK the engine RPM goes higher like normal but sounds a bit off. But when in drive, I step on gas and push pedal half way down from a stop and the car moves slow as if my foot is not even on the pedal but after several seconds it responds to pedal and I get up to speed.
I think it may be the TPS, I have tested it months ago by unplugging while idling and every time I did the engine would start idling very rough. But now when I unplug it while it idles there is no change at all. Can anyone comment on this?
When I open throttle at the TB the engine shows it loses power for a fraction of a second and when I release the engine shows a struggle for a second.
Old 09-15-2018, 09:44 PM   #4
So, how many miles on the 95?
Taking the O2 sensor out as billr suggested is a very good idea, you may find that the problem is a plugged catalytic converter.
Old 09-15-2018, 10:05 PM   #5
StrnWolf
1994 SL1
Car has 192,000 miles, the current catalytic converter has about 43,000 miles on it MAX.
Can the O2 sensor be removed and installed with manifold hot? Also what size socket do I need for it since I'll have to pick one up?
Old 09-16-2018, 06:03 PM   #6
StrnWolf
1994 SL1
I took a compression reading of each cylinder 35 days/1,200 miles ago and the results were: 1: 205PSI, 2: 210PSI, 3: 205PSI, 4: 210PSI. Should I take another compression test?
Old 09-16-2018, 06:05 PM   #7
StrnWolf
1994 SL1
Update: Today I wanted to see if it still has problem, and when I started engine it shut off right away. I cranked again and it started and was slow to gain RPM but then the RPM was bouncing and it is struggling hard to stay running.
Today I got a socket for the sensor, so I will try that test when able.
Old 09-16-2018, 06:45 PM   #8
Has the engine performance changed since 35 days/1200 miles ago? If so, then "yes", check compression again.
Old 09-16-2018, 08:39 PM   #9
StrnWolf
1994 SL1
Engine performance has not changed one bit and neither has the fuel usage. I keep close track to fuel usage and since I got the car about almost 3 months ago and 2,100 miles ago I am always getting about 20.5MPG which is 100% city mileage.
Everything has remained the same until yesterday, I drove car to a friends home, shut off engine for about 10 minutes. When I was going to leave I started the engine started fine as usual, but when I put in drive and stepped on gas nothing happened. I first thought maybe my wheels were against the curb but saw i was 1 foot away. I shutoff engine and started again and it started again fine but still the same problem.
Again, from a stop I stepped on gas and would even press pedal half way and the engine speed would be only 100RPM above idle speed for several seconds until after the few seconds in which it responded so I would get normal engine speed and would get up to speed. Even when driving if I released gas fully and then when I tried to go faster while still moving (such as go from 30MPH to 40MPH) I press pedal and for several seconds the engine would not respond, but after the few seconds it responded and I was able to increase speed.
Now with engine cold, it does not want to run, if it doesn't shut off it struggles to keep running while in park.
Old 09-16-2018, 10:28 PM   #10
1-Do you know how to test the map sensor? You can remove it for inspection for any carbon deposits blocking the small port on the sensor.
2-Was fuel filter ever replaced (every 100k miles)?
3-What's fuel pressure? A f/p gauge may be borrowed from Autozone or Advance Auto.
Old 09-16-2018, 11:47 PM   #11
StrnWolf
1994 SL1
1: Yes, that is on my list to test.
2: I believe so since the current filter does not look original
3: I do not know yet but it is on my list to test.
I am very busy every weekday so testing may be a while and I need to rent every tool. Right now I have the oxygen sensor socket so I can test the converter. If that passes I move onto next test.
Old 09-19-2018, 06:13 PM   #12
StrnWolf
1994 SL1
And so I believe the fuel pressure regulator is working on the count of engine idling changes when hose is removed. Now as for fuel pressure, at idle with vacuum hose attached I am getting 18.4 PSI, with it removed I am getting 19 PSI. After five minutes with engine off the pressure drops about 0.4 PSI.
After another look my fuel filter may be original to the car. Sadly right now I have no way to test pressure at the pump so all I can do is buy a new filter and cross my fingers it's problem solved.
It is hit and miss when my engine does not shut off right away, but anytime it does keep running, it always shuts off when I put it in gear.
2004 L300 Saturn Lacks or lose Power bobbycarmon L-Series Tech 5 11-07-2014 09:01 AM
99 SC2 1.9 middrange lacks power gmoncrief S-Series Tech 4 11-12-2010 09:51 AM
1998 SC2 lacks power gmoncrief General Saturn Discussion 2 07-10-2010 11:38 PM
Re: Car lacks power cool_jr256 S-Series General 0 01-08-2006 11:31 PM
My car lacks power cool_jr256 S-Series General 12 11-30-2005 12:05 AM
