Old 11-19-2017, 02:46 PM   #1
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default Removed passenger seatbelt to remove rear trim....
a bunch of things popped out when I pulled the bolt and now I don't know how it's supposed to go back together. Need some assistance
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 11-19-2017, 04:27 PM   #2
rgrafton
rgrafton's Avatar
2002 SC1
Default Re: Removed passenger seatbelt to remove rear trim....
This is my '02 SC1
Old 11-19-2017, 08:30 PM   #3
dummo
dummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nice
dummo's Avatar
1997 SW2
Disassemble the driver’s side except slowly and paying attention this time. Maybe set up a high speed camera to capture all the parts as they fly away from each other tumbling earthward.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 11-19-2017, 08:45 PM   #4
Not sure what's there to go flying, but...
Old 11-19-2017, 11:40 PM   #5
rgrafton
rgrafton's Avatar
2002 SC1
from your diagram, I took #2 and #1 off. The bolt (torx head) that holds the holster thing in, came out and then out popped a washer or two and a spring. It seems that it will take a good bit of force to compress the spring to get the bolt to the threads... but before that I need to know in what order all of these piece have to go
Old 11-20-2017, 11:42 PM   #6
macbox
macbox is on a distinguished road
macbox's Avatar
The passenger seatbelt in your 01 resembles the drawing in the lower left of the pic that fetchitfido posted, correct? I don't see any springs in this drawing, and my memory of my 01 SC2 is somewhat hazy, and for the upper seatbelt assembly to frame attachment I don't remember springs there. Is it the lower seatbelt to frame attachment you are wondering about?
#4, 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#5, 1998 SW2m, rebuilt at 126K, Totaled at 205K miles.
#7 1995 SC2, 121K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 11-21-2017, 02:55 AM   #7
magician22773
magician22773 will become famous soon enough
1997 SL
I don't remember anything like you are describing when I did my interior swap. Only thing even remotely close was some small part on the backside of the grab handle when I pulled the headliner. I am wondering if something broke and came apart, or if this was a piece added by previous owner for some reason.
1994 SC2 Retired
1996 SL "FrankenSaturn"
1998 SL2 FrankenSaturn's Body Donor
2004 Vue "What was I thinking?"
2001 SL1 100k Mile Baby Blue Beauty
1999 SL2 Thank You Tiger!
Add to magician22773's Reputation
Rate the quality of this post and help magician22773 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magician22773 is offline   Reply With Quote
Old 11-21-2017, 12:24 PM   #8
I don't remember any springs, either.
I removed 1 & 2 a month or two ago as part of the headliner replacement. (actually, maybe it was 1 & 14 on the far right of the diagram, the note at the bottom says "99 to present").
The #2 ( #14?) part will definitely drop when the bolt comes out, but I only remember washers, no springs
Old 11-21-2017, 03:06 PM   #9
rgrafton
rgrafton's Avatar
2002 SC1
Actually looking closer at the diagram, the part number #1 and #2 is for older S series models... There is no specific part number apparently for the bolt and top holster for my 3rd gen SC1; however, #6 on the bottom left of the diagram covers the entire assembly to maybe get a better idea.
But anyway, it's the same idea.. it is the bolt that holds the top part of the belt to the frame. There were a few washers, a spring, and lastly a metal cylinder piece that has a big end (which looks to hold the spring) and then a narrower end (that appears to stop the head of the bolt from going through)... The Metal cylinder itself appears to sit right inside the hole in the plastic seat belt piece. Also, one of the washers appeared to have sharp edges on it (sort of like a lock washer, but not sure).
I'll take a few pictures when I get home.
Old 11-21-2017, 09:45 PM   #10
rgrafton
rgrafton's Avatar
2002 SC1
here ya go:
Old 11-21-2017, 10:37 PM   #11
macbox
macbox's Avatar
The assembly is indeed part of #6 in the lower left of the illustration, but is not part of the detail of the illustration.
The first question is, what part caused the wear mark on the plastic? That part goes there.
2nd question is, what direction does the ferrule (the long brass metal part that holds the spring) face, does the small end go towards the frame or away from it?
My conjecture is:
The small steel washer goes on the ferrule first, then the spring obviously goes on the ferrule, the lock washer goes on the small end of the ferrule to act as a stop for the spring, then the two small brass washers go on either end to allow the assembly to rotate against the friction of the spring.
I think that for the most part, the sequence of how you have the washers and springs is correct, but it's a matter of where the big brass washer and the steel washer goes.
How to remove chrome trim from rear hatch (rust spots) NathanD Vue Tech 3 04-21-2018 03:44 PM
09 Remove rear trim threshold? gtgoat 2008 Vue 2 05-08-2012 09:02 PM
For those of you who removed the dash trim.... Low Saturn Aura General 8 01-09-2010 01:46 PM
Seatbelt trim plastic piece (broken tab) mr18436572 S-Series General 7 04-24-2009 09:07 PM
Passenger seatbelt light keeps going on! alfkorda Ion General 4 01-19-2007 09:44 AM
