Old 11-13-2017, 03:39 AM   #1
MHZ-711
MHZ-711 is on a distinguished road
Default CV Axle replacement: transmission fluid replacement question
Aloha!
First post....
Model: 2003 VUE V6 3.0L 2WD Automatic
Fluid: Dexron-VI Automatic Transmission Fluid
I'm trying my hand as a first time DIYer and took on some overhaul of my driver side wheel area to replace: wheel hub; sway bar link; tie rod end; and cv axle.
While replacing the axle, I was ready to catch the transmission fluid when I pulled the CV axle free of the transaxle. I lost a tad more than 1-quart that needs to be replaced and I want to make sure I have this part of the procedure correct. I was using the Haynes Repair Manual and a couple of helpful YouTube videos, but they are a bit vague on the refill portion.
1) Do I replace the fluid through the dipstick port just forward and below the engine?
The procedure I was going to use is:
- Idle engine for ~3-5 min
- shift through all gears, stopping at each for 10 sec, end at PARK
- check fluid level
- Add transmission fluid a little at a time, carefull not to overfill
2) What level do I want to fill to according to the dipstick?
Any help from you seasoned veterans will be greatly appreciated!
Mahalo!
Add to MHZ-711's Reputation
Rate the quality of this post and help MHZ-711 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MHZ-711 is offline   Reply With Quote
Old 11-15-2017, 08:45 PM   #2
atikovi
Default Re: CV Axle replacement: transmission fluid replacement question
Knew that dipstick looked familiar. Same as my Volvo C30. So it's an Aisin transmission? There should be a fill plug at the top but you might have to take off a bunch of stuff to get to it. Quicker to fill through dipstick hole. Problem is most funnels are too large. If you go to any auto glass shop, you can get the nozzle they use for the glass adhesive and it works great as an adapter for a funnel.
Add to atikovi's Reputation
Old 11-16-2017, 09:32 PM   #3
Chazberry
Chazberry's Avatar
Welcome aboard!
Yes - there is no other Fill Port. Some additional details in this thread . . .
http://www.saturnfans.com/forums/sho...d.php?t=158509
Some more service information attached.
Add to Chazberry's Reputation
Old 11-16-2017, 10:09 PM   #4
Chazberry
Chazberry's Avatar
PS - you would be well-advised not to let any "Quickie Lube" type place change your Oil Filter. They invariably over-tighten the cap, it jams, and you wind up with a major repair on your hands. That cap only needs to be slightly snug.
Old 11-19-2017, 02:54 PM   #5
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
Aloha!
First post....
Real quick...not sure if anyone else saw this, but the 2002 and 2003 V6 Vue's with the Aisin 5 speed transmission DO NOT use Dexron VI.
They use ATF T-IV. GM dealers sell T-IV in a relabeled bottle at a markup, so you can definitely get it from a GM dealer if needed.
The cheapest place I've found to get T-IV is from your local Toyota dealer. It's usually about $5 a quart.
Dexron VI is a very thin ATF compared to T-IV, so I would be concerned about replacing the T-IV in an Aisin transmission with Dexron VI.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Axle seal replacement question Hjoken S-Series General 1 07-23-2012 12:51 PM
transmission fluid filter replacement jazzbow Vue Tech 25 11-18-2011 01:58 AM
manual transmission fluid replacement chinkey1234 S-Series Tech 5 08-29-2010 05:15 PM
03 Vue Axle Replacement Question Staleek Vue Tech 8 11-25-2007 03:05 PM
Manual Transmission Fluid replacement Aztek_SC2 S-Series General 7 03-04-2007 12:40 AM
