Old 02-17-2007, 04:39 PM   #1
dwmac
dwmac is on a distinguished road
2004 L-Series 3.0L Wagon
Default L300 Thermostat housing
I am replacing my thermostat on my L300 v6, upper plenum is off, how do I get the thermostat housing out with out removing the intake, I have try every possible angle but no success, any input would be great.
Thanks
dwmac is offline   Reply With Quote
Old 02-17-2007, 08:05 PM   #2
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: L300 Thermostat housing
No way I am aware of. Take the lower intake off, and it is pretty easy.... as easy as it can get with the limited space....
Old 02-17-2007, 08:37 PM   #3
dwmac
Great thanks, I hoping to avoid but would save any frustration. One other question while I have your attention, the connetor pipe, do you need to remove the rad, it seems the power steering hose and dip stick are in the way, and the rad as well, would removing the power steering add anough space to remove this so new seals can be placed on it
Old 02-19-2007, 02:04 AM   #4
Bigdaddy94sc2
2006 ION-2 Sedan
Just loosen hte bolt. Slide the pipe forward just enough to get it loose from the tstat housing. Once loose, take the housing out, and repalce the seals on the pipe while it is through the head.... easiest way to do it. But to remove the pipe completely, yes the rad has to come out.
Thermostat housing leaking rileygsp S-Series Tech 3 11-03-2009 12:00 AM
Charged for thermostat housing?!! saturnmom77 S-Series General 10 03-10-2009 12:23 AM
Stubborn thermostat housing bolt ahab_us S-Series Tech 14 01-26-2009 11:01 PM
Thermostat Housing Bolts rockettjay S-Series Tech 21 04-14-2008 12:45 PM
Thermostat housing bolt splat Miscellaneous Tech 4 05-15-2004 06:42 PM
