Old 05-12-2011, 08:15 PM   #1
2000mc
2000mc is on a distinguished road
1999 SC1
Default swapable seat covers?
so my 99 sc1 w/209k is showing some wear in the seat department, more so on the drivers seat than the passenger, which looks almost new in comparison. to me the seat covers/cushions/padding look very similar from left to right.
anyone know if the covers and padding will actually swap? or at least reasonably nicely... w/o some big spot left exposed or fitting very poorly. does the drivers seat belt support up on the seat back cause issues? is it part of the seat back frame or unbolt? need hog rings when i do this?
2000mc is offline   Reply With Quote
Old 05-12-2011, 08:34 PM   #2
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
1994 SL2
Default Re: swapable seat covers?
yeah they will swap, i think differnt racing has a how to
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Saturninin is offline   Reply With Quote
Old 05-13-2011, 09:53 AM   #3
The passenger seat is a bit wider then the driver seat. Dunno if it makes a huge difference with the covers & padding or not, you could probably fix it easy enough with hog ring's & pliers.
Old 05-13-2011, 11:04 AM   #4
someone added padding to their driver seat fairly recently. they sandwiched a 1" piece of new foam in between two pieced of thin cardboard, squeezed, and used the cardboard to slide the new foam under the worn foam, then pulled the cardboard out when positioned.
Old 05-17-2011, 09:06 PM   #5
2000mc
1999 SC1
update
99sc1, manual seats, 3door, 209k mi
swap is done. easy to do as could be asked for. bottom cushion swaps left to right as soon as the tracks are unbolted from it. the seat back cover/padding are removed from the frame, and a small section of padding cut out for the drivers seat belt guide. 2 hog rings are used on each seat back. didnt know that the covers were glued onto the padding, at least the backs are, didnt have the bottoms taken apart at all.
while the main reason i swapped was because i had started to wear a hole on the outer edge of the drivers seat back cover. i had also noticed the padding was squished down more than the passenger side.
so now the seat itself is noticeably more comfortable, and the seat covers get a big boost in the mileage they will wear for.
there was an unintended consequence however. while i knew the padding was worn, the change went beyond optimal and a bit into 'booster chair' territory. at least for someone at 6-1, this would probably just be an added bonus for short enough drivers that really want a lil more height.
seat covers Saturninin S-Series General 3 07-21-2009 11:35 PM
Seat Covers mr tibbs S-Series Mods 5 12-30-2006 03:41 PM
vue seat covers/seat pockets electricbluevue Vue General 2 06-09-2004 10:09 PM
seat covers kilkenny123 General Saturn Discussion 3 08-08-2002 08:38 AM
seat covers blondie General Saturn Discussion 1 05-16-2000 08:39 PM
