Old 03-05-2019, 01:23 PM   #1
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default Oil drain plug gasket
Since my last oil change, I've noticed that oil has been leaking from the plug on the oil pan so I bought a new OE gasket off amazon to use next time I change the oil. Eariler this morning when I was changing the oil though, looking at the plug there was a white plastic on the underside of it. Is that what's normally there or is that an old gasket? I tried getting it off but it was either really stuck or isn't meant to be removed. The new gasket fit pretty good in it so I assumed it was just the guide for where the gasket sits. Once everything was back together I think it might still be leaking, but I also forgot to wipe everything down after draining the oil so it might just be from when the oil was draining. I'll keep an eye on it for the next few days. Does anyone know what the plug is supposed to look like though? Trying to make sure I didn't double up on gaskets cause then it'll almost certainly still be leaking
Thanks for the help.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-05-2019, 02:15 PM   #2
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Default Re: Oil drain plug gasket
looks like you are doubling up on gaskets - looks like the white one is the old dried up cracking and leaking gasket. - (Dummo's opinion which is not worth much usually)
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 03-05-2019, 02:34 PM   #3
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Double gasketed. Just keep on monitoring the level, SOP for us Saturn S-series owners.
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 03-05-2019, 03:05 PM   #4
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
If it's really old, the normally pliable rubber will harden, becoming almost plastic-like and it can fool you into thinking it's supposed to be there. I've made that mistake on other gaskets, including the oil plug!
If it's hard to get out, try using a razor blade to space it away from the plug. From there you can probably "unscrew" it by moving it with the plug threads.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 03-05-2019, 06:56 PM   #5
The white nylon gasket must be removed before installing a replacement. You can use the OEM style rubber that you buy through Dorman or you can use a nylong gasket. Either gasket is not a lifetime part and must be replaced periodically, best bet is every other oil change.
Old 03-05-2019, 09:25 PM   #6
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Rock Auto has them in packages of 10 for pennies each. I bought 50 in one shot. Take no chances, it is always that 10 cent part that takes you out.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 03-05-2019, 10:41 PM   #7
toggenburg
toggenburg's Avatar
Interesting, how come, in over 50 years of car maintenance, and a whole lot of 3k oil changes, so how come I have never had any oil pan gasket disintegrate and I haven't ever replaced those gaskets?
Mine always seal tight and don't leak.
What's all the fuss about replacing them like every other oil change??
Do you truly find this is a real problem, and needs this extra attention?
I never have.
Owned probably 20+ cars and trucks, one has 331K on a vortec 350, and I consistently drive about 30k per year....so conservatively have well over a million miles on my driving record and no gasket issues. Ford, Dodge, Chevy's, Audi, Fiat, MGA.....
Old 03-05-2019, 10:54 PM   #8
I never have.
A few have copper crush washers and last a good long time IF NOT OVER TORQUED. The nylon and rubber have a very definite service life and the nylon will outlast the rubber ones. You would be surprised just how many of the supposed leak tight drain plugs are leaking as the car runs down the road.
Old 04-03-2019, 03:04 PM   #9
Zeebins
Zeebins's Avatar
Little update for this thread,
It's been about 500 miles since I changed the oil with the new gasket and even though it's double gasketed, it doesn't seem to be leaking at all. The bottom of the oil pan and around the bolt is all dry. Normally every 500 miles or so I'd be about 3 diamonds low on the dipstick but currently it's not even half a diamond low. Seems pretty good to me. I already have another gasket to put on when I change the oil again so I don't have 2 on the bolt but for now it seems to be doing okay.
Powered by Plastic
Old 04-03-2019, 05:37 PM   #10
It is surprising how much oil you "burn" with a slight oil smudge around the drain bolt.
Old 04-03-2019, 05:47 PM   #11
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
I never have.
My 1999 Ford Escort had a better system and I never had to replace it. The 2000 Saturn SL2 has an indent on the bottom of the pan and it ends up damaging the gasket after 8 oil changes. All garages keep gaskets and for a few cents, just put on new ones. I don't think some of my past oil changes at some garages even billed me for for some.
Old 09-06-2019, 03:06 AM   #12
Zeebins
Zeebins's Avatar
The double gasket definitely started leaking at some point. I was sure to remove the old one this time. It was not easy to get off, I ended up having to cut it
File Type: jpg 7AA2397C-4E53-43F6-ADB9-BAFA1FC4D62F.jpg (145.3 KB, 35 views)
File Type: jpg 66CB7BFA-0FF7-430E-BF42-5D34528CF17B.jpg (144.7 KB, 36 views)
Powered by Plastic
Old 09-06-2019, 03:11 PM   #13
454cid
I'm surprised I didn't see this thread when I was trying to figure out my oil drain plug. I ended up having to buy an AC Delco plug that looks like the one in this thread. The Needa plug I bought first, used a much smaller diameter gasket... it might work, but I didn't want to chance it.
Goofiest oil drain port I've ever seen.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-10-2019, 01:54 PM   #14
TomM96
In Early August i replaced my last OEM Saturn gasket with a Dorman item from China as Zee illustrated above.
The new Dorman gasket is leaking (spots on ground where parked).
On this Saturn, the previous owner, and also myself, painted the oilpan
to prevent corrosion. The edge of the paint cuts/abrades the soft OEM
gasket. I looked forward to the harder Dorman gasket... but now I may
try nylon too....
Add to TomM96's Reputation
Old 09-14-2019, 11:47 AM   #15
lilwhitetruck
lilwhitetruck is on a distinguished road
The Dorman gaskets don't work at all. I did the same thing and they leak also. Since I have a box of 100 or so I used them every oil change and just monitor the leakage.
2001 Saturn Silver SC2 Leather Interior with 297K and a newly acquired 2002 White Fully Loaded, With only 87K! My new DD!!!
Add to lilwhitetruck's Reputation
Rate the quality of this post and help lilwhitetruck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lilwhitetruck is offline   Reply With Quote
Old 09-14-2019, 12:48 PM   #16
There are 2 different pan configurations.
Old 09-17-2019, 10:22 PM   #17
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
If you need a recommendation for a good drain plug and gasket, there's a thread out there where someone used the plug and nylon gasket from a Chevy Cavalier and had good luck. I tried that config and have had no leaks whatsoever. On Amazon it says it won't fit your Saturn but it fits fine. At first I tried the rubber gaskets made by Dorman and still had a leak but these nylon ones are great.
Gasket:
Dorman 097-117 AutoGrade Nylon Oil Plug Gasket
Plug:
Dorman 090-091.1 AutoGrade Oil Drain Plug (it's magnetic too)
Hope this helps! Good luck!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 09-30-2019, 12:07 AM   #18
Haybale
Haybale is a jewel in the roughHaybale is a jewel in the roughHaybale is a jewel in the rough
Haybale's Avatar
Even easier and cheaper.
A standard garden hose gasket is perfectly fine. I have used them for years.
Get a 10 pack on a stick at home depot, or any garden store!!!!
The may be very slightly bigger than the shoulder of the drain plug, but the squish out around the edges.
https://www.acehardware.com/departme...B&gclsrc=aw.ds
Ryan
97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15
98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP
S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
Add to Haybale's Reputation
Rate the quality of this post and help Haybale reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Haybale is offline   Reply With Quote
Old 09-30-2019, 11:01 PM   #19
NWSaturn247
Son of a gun, perfect fit! Got these at Fred Meyer for 69 cents. I will use a new one at every oil change! (I'm Swedish )
Thank you Haybale!
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-01-2019, 09:43 AM   #20
454cid
Interesting idea. I may look into that.
1999 Chevy K3500
Transmission Drain Plug Gasket Wray Vue General 2 07-11-2014 10:41 PM
Drain Plug Gasket Size MattBarszcz S-Series General 2 10-12-2011 11:30 PM
Oil drain plug gasket bez S-Series Tech 8 03-09-2009 08:18 PM
Oil drain plug gasket 93goldsl2 S-Series Tech 6 07-13-2007 11:24 PM
Need advice on oil drain plug gasket... Tiger S-Series Tech 20 06-17-2005 08:49 PM
