Old 10-22-2019, 12:18 PM   #1
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
Default Ignore the rear O2 = P0141 ??
So my car threw a check engine light and it turns out to be the rear O2 sensor via P0141. From the forums here, it looks like a pretty simple fix - if you can raise the car and get access to the sensor.
On the other hand, it has no effect on performance, but won't let me pass smog. That said, I just passed CA smog in August, and so have another 21 months before I have to worry about it again. And the light turned itself off after driving to work this week. Go figure...
I'm still waiting for the wheels to fall off, so I'm inclined to leave it alone for now - what do ya'll think?
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 10-22-2019, 01:08 PM   #2
Pitcher
Pitcher's Avatar
Default Re: Ignore the rear O2 = P0141 ??
Given what you said... Leav 'er.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-22-2019, 01:20 PM   #3
Since it turned itself off . . .
if it comes back on and if the wheels haven't fallen off in 15 months, worry about it then
Old 10-22-2019, 06:18 PM   #4
One of my trucks had P0141. It'd stay off if I just went to work & home (7 miles each way) but if I took at 20 mile trip anywhere it'd turn back on until 2-3 more trips to only work & home. Something to do with how the sensor is checked/tested.
Old 10-23-2019, 01:05 PM   #5
Originally Posted by blueknigh7 View Post
......On the other hand, it has no effect on performance, but won't let me pass smog. That said, I just passed CA smog in August, and so have another 21 months before I have to worry about it again. And the light turned itself off after driving to work this week......I'm still waiting for the wheels to fall off, so I'm inclined to leave it alone for now - what do ya'll think?
I'd plan on six months before emissions inspection if the check engine light turns on for any reason to address it before you jump thru hoops in repairs and various suggestions from members here. Or three months before inspection. Plenty of time to address issues without pressure to fix something under a time constraint.
If the same error code reappears (P0141), address it at your convenience as its announcing a repeating problem that won't go away and may cause you grief later when emissions inspection comes around.
P0141 replaced rear O2. sevice light still on Dsaturn L-Series Tech 15 08-15-2017 03:59 AM
Ignore list link-ignore the trolls bobyjones Community Center 0 11-18-2012 09:43 AM
ignore dp97sc2 General Saturn Discussion 0 06-04-2005 02:54 PM
ignore me! Spazie Events 1 03-01-2005 12:51 AM
ignore ChrisION Ion General 1 09-20-2004 04:23 PM
