Old 10-01-2019, 10:50 AM   #1
Tackl123
Tackl123 is on a distinguished road
Default Aura remote start
Hi. Iím installing remote start in my 2007 aura xe. It was going great until I got to the starter wire. It says on the installation sheet for the auraís that the starter wire can be found under the hood by the fuse box or at the starter. Doesnít tell me any colors and I cannot find the right one. If someone could point me in the right direction it would be great.
Add to Tackl123's Reputation
Rate the quality of this post and help Tackl123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tackl123 is offline   Reply With Quote
Old 10-01-2019, 02:44 PM   #2
Default Re: Aura remote start
Every starter uses two wires, the large red battery cable and a smaller wire. Both are on separate terminals. A third wire on the same starter terminal with the battery cable sends power to the alternator. The single wire on the starter (small) terminal is the START wire, a 12v signal sent from either a start relay for electronic starting or from the ignition switch in non electronic starting.
Examine your aftermarket remote system wiring schematic and descriptions. If the start signal from the remote module is a 12v signal, it must be able to supply several amps because the starter solenoid is powered by this 12v start signal. About 5 amps or less is needed to power the starter solenoid. Once the starter solenoid powers up, it does two things; pulls out the starter gear to engage the engine flywheel while closing a set of large contacts inside the solenoid housing to send battery power to the starter motor, turning on the starter.
Old 10-02-2019, 06:42 AM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
I thought remote start was standard on Aura's?
Does your remote look like this (If you have it). If it does, pressing lock for a second, then holding the top button, for a few seconds, should start the car. (As long as the check engine light is not on)
What's the make and model of your remote start. Did it come with an immobilizer bypass module.
https://northcoastkeyless.com/wp-con...24-MAIN1-7.jpg
Old 10-02-2019, 10:43 AM   #4
Tackl123
I was told that remote start is normally always put in from the factory in the aura's but there's only an unlock, lock, trunk and alarm buttons.
Old 10-02-2019, 12:09 PM   #5
imaddicted2u
2008 AURA XE
Might not have been include, I've been wrong before. My 2008 XE has it.
The factory remote start is just software installed in the Body Control Module.
I wonder if you have the original remote? Sadly with the Aura it's not easy to add remotes. The dealer has to program them.
Look in the glove box, there is an options tag in there...see if AP3 is listed.
That's the option code for...
LOCK CONTROL, ENTRY REMOTE, KEYLESS ENTRY, START
If you can post a clear pic of the tag, I'll try to decode the options list for you.
Old 10-02-2019, 12:16 PM   #6
Tackl123
My dad works at a dealership and he programmed the two remotes I have now. My car doesn't have the remote start included, sadly. Thanks for your help
Old 10-02-2019, 12:25 PM   #7
imaddicted2u
2008 AURA XE
You should get your Dad to see if the factory remote software can be installed in your car.
Here is a schematic of the start circuit. Hope it helps.
https://i.imgur.com/uKsTM5x.jpg
How to tell if aura has Remote start(without fob) buCKshoTZ Aura General 30 11-13-2019 09:43 PM
Aura remote start? Hackettbr1 Aura General 28 05-10-2018 02:00 PM
Saturn Aura Remote Start xlevix10 Aura General 1 04-07-2016 03:47 PM
Saturn Aura Remote Start dgaugler Community Center 0 11-24-2008 08:22 AM
Remote Start 07 Aura bradt123 Aura General 1 02-26-2007 01:51 PM
