Old 06-29-2004, 07:01 PM   #21
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
Well Luke at least we now know that changing the auto mount is DIFFERENT from changing the manual mount!
I noticed this on my brothers '95 SL2,that auto trans is quite a beast!
And yes,I did cover my hide by mentioning this was MANUAL TRANS ONLY folks!
Also,state I don't recommend trying this yourself,just for that reason,it's a hard procedure if you're inexperienced,unsure,or skittish........
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 06-30-2004, 02:07 PM   #22
geartooth94
geartooth94's Avatar
Default
Luke, maybe you can get a Dremel-type tool in there or a rotary cutter of some sort to cut off the stubborn bit of bolt that won't come out on its own.
Then you could finnagle the new mount in somehow. Don't know if this would work for you though.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline
Old 06-30-2004, 03:55 PM   #23
Luke
Luke's Avatar
Default
Thanks, but I've already finished the job, but it certainly was a challenge. In the future, your suggestion will be on my mind.
Add to Luke's Reputation
Luke is offline
Old 07-02-2004, 08:10 AM   #24
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default
Many Thanks to auxmike for the procedure.....excellent. I need to replace mine at some point on my '01 SC2 5 spd as I have windo welded my two dogbones and replaced the upper torque-axis mount. A question please...auxmike what was the net change in driving performance with your 5 speed car after changing the trans mount? These cars are known for driveline rock in lower gears when getting on and off the throttle with the clutch out. Does a fresh mount reduce this tendency? Was curious if there was a noticable difference after changing the mount as the two dogbones allow quite a bit of driveline rotation in profile and presume a fresh solid mounting of the trans to the sub frame will quiet this down a bit. Please let us know.
Thanks,
George
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline
Old 07-02-2004, 06:43 PM   #25
auxmike
auxmike's Avatar
Default
gm7:
I guess I've been fixated on how it feels at idle more than looking for a jerking motion while driving,I confess.
I can still chirp 'em from 1st to 2nd in my basicly stock moded car.
I'd say judging by how much more squished the old mount was vs. the nice "tall" new mount,it was time for a fresh unit anyways.
I can't say if I notice any jerking while driving because I guess I don't!
Sorry if this seems a pretty weak answer to a great question.
Hey,for under $40,it's about an hour's worth of work that can be considered fun if you like to tinker like I do.
Since you have an '01,you may still be in decent shape with the original mount.
I had done this on a '97 with 71k on the clock myself.
DON'T USE THE WOOD FENCEPOST METHOD!
Take your time,jacking up and down SLOWLY as you watch.The axle boot on the tranny bends A LOT when you jack it up,be careful...
auxmike is offline
Old 07-02-2004, 07:59 PM   #26
gm7
gm7's Avatar
2009 VUE Red Line
Default
Thanks for your response Mike. As you say I may still have some life in that mounton my '01 car. Your procedure is terrific and is a big help to all that will take this on including me. Thanks for your contribution to the board.
Best Regards,
George
gm7 is offline
Old 09-11-2004, 03:45 PM   #27
FrozenPilot
FrozenPilot's Avatar
Default
I didn't see differences for the AUTOMATIC crowd, so since I just tackled that job, heres what I found:
-You will need to remove the battery and battery tray to lift the tranny high enough
-You may not need to remove a transmission strut bolt, but it may help.
-You will need two jacks, i will get to this in a sec
-Unbolt the engine mount from the bracket on the rail, jack up the engine under the oil pan for starters
-Now get your other jack and place that under the tranny, keep an eye on how that is lifting, you may need to pull the engine toward the passenger side to get enough clearance
-With that done, replace the mounts and start working in reverse
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Old 09-12-2004, 10:26 AM   #28
Luke
Luke's Avatar
Default
Super outline
Luke is offline
Old 09-13-2004, 07:46 PM   #29
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
im still tryin to figure out why u have an 8' long post in the back of ur car??where u fit that? i just cant see sumone standin there swingin a piece of wood that big..ha
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 10-26-2004, 06:06 PM   #30
emptypockets
emptypockets is on a distinguished road
emptypockets's Avatar
1999 SC1
Default
A jack under your oil pan?... Isn't that kind of like standing on a pop can?
Add to emptypockets's Reputation
Rate the quality of this post and help emptypockets reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emptypockets is offline
Old 10-26-2004, 06:16 PM   #31
auxmike
auxmike's Avatar
Default
You must put a piece of wood between the oil pan and jack,so you don't dent the pan.
auxmike is offline
Old 10-27-2004, 08:28 AM   #32
TedL
TedL is on a distinguished road
Default
I wound up removing this mount as part of the procedure to tighten the input and output shaft nuts.
To answer the brake master cylinder question: The FSM noted that if you have ABS, you must disconnect the master cylinder from the booster and lift it a bit.
Also, you want to have the floor jack under the tranny, as Mike shows, not under the (engine) oil pan.
I managed to get the mount back in place without major problems. First, I tried dropping the mount into place, and loosely installing the 15 mm nut from the bottom. Then I lowered the tranny and looked to install the 10 mm bolts. The alignment was off by a few mm, and I've learned not to try installing bolts into aluminum when the alignment is less than perfect.
So, off came the 15 mm nut and up went the tranny. I then installed the mount loosely to the tranny with the 10 mm bolts, and lowered the tranny while guiding the mount stud into the cradle rail. I did a little bit of push/pull, but don't recall needing any pry bar. Before the mount got down to seating on the rail, I torqued the two 10 mm bolts, then let it bottom, then tightened the 15 mm nut.
Perhaps my angles were a little different, becuse my cradle was dropped about as far as can be with the two left side bolts loosened (but not removed). In any case, the moral of the story is make sure the holes line up before installing the two 10 mm bolts, don't use them to force alignment. Aluminum is not very forgiving!
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 10-27-2004, 05:26 PM   #33
auxmike
auxmike's Avatar
Default
[/B]
This is correct!I was thinking of the upper engine mount install where you would need jack up the oil pan.Not the case with the lower mount.
.You don't want to jack up the oil pan to change that lower mount,won't work.
Don't do that!
auxmike is offline
Old 11-19-2004, 06:11 AM   #34
SL1Joe
SL1Joe has a spectacular aura aboutSL1Joe has a spectacular aura about
SL1Joe's Avatar
Default Re: HOW TO:Change lower tranny transmission mount
Looks like I will be doing this repair in the very near future, I had the front of the car up on the stands today trying to pinpoint the source of a noise the sucker makes when making left turns and accelerating (almost sounds like rubbing but high pitched and goes away once I attain a certain speed). Anyhow while I was at it I removed the splash shields to check the tranny mounts since I had the tire off anyway why not, still tryin to stamp out all the vibrations in the car (I'm still not convinced it's a normal Saturn trait but thats just me). I noticed the lower tranny mount is just about shot *ding* *ding* I believe we have now discovered the vibration source and it would also explain why only the left side of the dash rattles. Dog Bone mounts appear to be fine will probably replace the upper motor mount as well couldn't hurt right..
Add to SL1Joe's Reputation
Rate the quality of this post and help SL1Joe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL1Joe is offline
Old 11-19-2004, 09:23 AM   #35
Luke
Luke's Avatar
SL1Joe
We'd appreciate your follow-up on your efforts; However, would you move them, and initiate the results, to the Tech Tack forum. As you know, this, How-To forum, is used to submit the actual "procedures" for work efforts.
Just a thought....
Luke is offline
Old 11-21-2004, 12:08 AM   #36
SL1Joe
SL1Joe's Avatar
Originally Posted by Luke
SL1Joe
Just a thought....
I intend to Luke, was mearly posting a reply.
If however I do discover another way to do it I'll post those thoughts here to share them with everyone else.
SL1Joe is offline
Old 11-21-2004, 10:43 AM   #37
Luke
Luke's Avatar
FM Joe
, Please
Luke is offline
Old 12-14-2004, 01:01 AM   #38
frog8546
frog8546 is on a distinguished road
frog8546's Avatar
I am SO glad I found this forum! I am not tech savvy and really appreciate the pics. I've known for a couple of weeks that the tranny mount needed replacing and was skeptical about trying it myself, but couldn't see forking out the cash to have it done.
Add to frog8546's Reputation
Rate the quality of this post and help frog8546 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
frog8546 is offline
Old 08-08-2005, 05:45 PM   #39
Civic&Saturn
Civic&Saturn is on a distinguished road
Civic&Saturn's Avatar
Default Re: Changing Lower Tranny Transmission Mount
Just did this procedure over the weekend and have a little more info to share that others might find useful.
First of all, there were no clearance issues at all in the engine compartment. This was on an SL2 with manual tranny and ABS, and I did not have to remove anything for clearance.
Secondly, I pretty much followed the procedure as detailed, although I loosened (but did not remove) the upper bolts prior to lifting the transmission with the jack.
Third, I also saw how the new mount did not quite line up properly, but it really was no problem. When the old mount was raised high enough to clear the cradle, it popped out (towards the brake assembly) and back (towards the firewall). I put the new mount in the cradle, put the cradle nut on just enough to keep it from falling out, then my dad gently tilted the new mount towards the brake assembly as I slowly lowered the transmission. As it lowered, the upper bolt holes lined back up, and my dad could start both bolts by hand. I then finished lowering the transmission and tightened both the upper bolts and the cradle nut. No 2x4 necessary!
Thanks to the original poster and everyone else who contributed. This procedure was fairly easy to do because of the info shared here.
Add to Civic&Saturn's Reputation
Rate the quality of this post and help Civic&Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Civic&Saturn is offline
lower transmission mount bdobraj S-Series General 12 05-26-2009 08:09 PM
Where can I get the lower transmission mount? latestgood S-Series Tech 6 04-15-2008 04:53 AM
Vibration after changing TAM & Lower Mount ssgjimbob S-Series Tech 3 08-26-2006 10:43 PM
Yes, another lower tranny mount thread. 91SL1 S-Series General 12 05-27-2006 12:35 PM
Changing Lower Engine mount s1sharma S-Series General 2 11-30-2004 11:55 PM
