Old 09-29-2003, 07:52 PM   #21
Craig
Craig is on a distinguished road
Default
I set up a water injection system on my '95 SW2, using the airbox resonator muffler as a container for water/alcohol and running a length of vacuum hose to a brass aquarium valve and on to an unused port on the throttle body ('94 and down use this port for the EGR). This has worked pretty good; lower emissions, better gas mileage, improved performance (especially with alcohol), and the combustion chambers must be carbon-free, because at the last 30K service the plugs were very clean.
Add to Craig's Reputation
Rate the quality of this post and help Craig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Craig is offline
Old 09-29-2003, 09:27 PM   #22
amazinghl
Default
Detail with pictures, please.
How much lower emission? How much better gas milage? How much water? How much performance?
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 10-21-2003, 08:10 PM   #23
92saturnsl2
92saturnsl2 is on a distinguished road
92saturnsl2's Avatar
Default
I did this procedure today using about 2 quarts of water.
I poured the water in on the fast side, the engine started to stumble on more than one occasion. Upon completing, the engine still misfired a little bit for at least 30 seconds or so, then continued to run normal.
There was a small puddle of water on the ground, and heavy steam was coming out of the tailpipe for at least another 30 seconds. The "steam" did resemble oil burning somewhat, as it had a slight blue hue to it, but it did not smell as if any oil was burning.
Well see if it did any good after the drive to/from work tomorrow. Thanks for the tip!
Add to 92saturnsl2's Reputation
Rate the quality of this post and help 92saturnsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92saturnsl2 is offline
Old 10-31-2003, 05:26 PM   #24
paramour
paramour is on a distinguished road
Default
Man, I haven't heard of this procedure for many years. My dad's old mechanic was a big proponent of this; I remember doing it to my dad's '71 Olds 98.
Add to paramour's Reputation
Rate the quality of this post and help paramour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paramour is offline
Old 11-22-2003, 11:39 PM   #25
mclarenf1gtrv12
mclarenf1gtrv12 is on a distinguished road
Default should i do it
yes i checked this post and i was wondering something.my CAR HAS ABOUT 10,265 MILES ON IT. should i do it this early in engine life and will it make a DIFFERNCE OR DOES THIS PROCESS ONLY WORK SUBSTANSALLY ON HIGH MILEAGE ENGINES .???
Add to mclarenf1gtrv12's Reputation
Rate the quality of this post and help mclarenf1gtrv12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mclarenf1gtrv12 is offline
Old 11-23-2003, 12:59 AM   #26
92saturnsl2
Default
It certainly wouldn't hurt, however I doubt much carbon has accumulated on an engine that new.
I suppose if you do this religiously (i.e every 10k or whatever interval), the carbon would not have a chance to build up significant amounts, and may help in the long run.
Old 11-23-2003, 09:59 AM   #27
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
Where does the carbon go?Will it clog up the exhaust valves of you free up all that carbon in one shot?
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 11-23-2003, 11:20 AM   #28
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
The water softens the carbon and mixes with it causing it to burn out of the cylinders in the form of steam. I wouldn't do it to an engine that new. You also have to be pretty careful with this procedure as a little too much water will be the end of that nice new engine.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 03-25-2004, 10:25 PM   #29
Petey
Petey is on a distinguished road
Petey's Avatar
2004 VUE 3.5L
Default
I this the same thing as putting MMO into the crankcase, fuel system, and/or doing a piston rign soak with it?
97 SL2 5-speed 190K, black & gold w/ gold trim, power package, sunroof, spoiler
06 TrailBlazer 90K
Add to Petey's Reputation
Rate the quality of this post and help Petey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Petey is offline
Old 04-04-2004, 03:50 PM   #30
diestrutionomeg
diestrutionomeg is on a distinguished road
diestrutionomeg's Avatar
1992 SL2
Default
I just performed this procedure yesterday, used a half gallon of water. No problems at all, lots of steam coming from the tailpipe, and a nice black suit left on the cement... opps. However, afterwords, i got in, and drove it off. I noticed a gain in power, and today i pulled the plugs, they were almost as clean as when i got them. Thanks for the procedure.
Now, how often do we do this to keep everything nice and clean?
-Omnicron
92 SL2 133,xxx
Add to diestrutionomeg's Reputation
Rate the quality of this post and help diestrutionomeg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diestrutionomeg is offline
Old 04-07-2004, 09:46 PM   #31
thewretched
thewretched is on a distinguished road
thewretched's Avatar
Default
this might be a dumb question, but how do you know how high you're revving it if you're outside pouring water into it?
Add to thewretched's Reputation
Rate the quality of this post and help thewretched reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewretched is offline
Old 04-07-2004, 09:51 PM   #32
splat
splat is on a distinguished road
Default
go inside and rev it...listen to it...then match that up while you're on the outside...be safe do it to about 2500...another thing you can do is a 50/50 mix of denatured alcohol and water.
Add to splat's Reputation
Rate the quality of this post and help splat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
splat is offline
Old 04-08-2004, 09:49 AM   #33
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Question
This is an interesting thread! Following this procedure with either water or a solution of water and alcohol sounds like a good idea.
I am curious. Could we do this with Berryman B-12 or the popular Marvel Mystery Oil (MMO) too? If so, how would the results compare to doing the cleaning with either water or water/alcohol? Better? Same? Worse? Or would this be a bad idea since these two products are probably flammable?
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 04-08-2004, 11:20 AM   #34
amazinghl
Default
They're too rich to burn, like carb cleaner. Don't pour them in, spray them if you must.
00 Insight 72mpg
Old 04-08-2004, 06:03 PM   #35
92saturnsl2
Default
I doubt those products are water soluble. MMO and other strong solvents will probably burn before they do much of anything as they are not in the combustion chamber long enough.
Old 04-09-2004, 02:43 PM   #36
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Cool
Thanks. I'll give it a try using water.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-09-2004, 03:08 PM   #37
thewretched
Default
awesome.
I just tried this (and I am by no means a mechanic. It took me more time to figure out how to get the hose off of the TB that to do the whole process). I used about 1/2 gallon of water. I'm not exactly sure how much stuff I got out, though there was a decent sized black ring on my driveway.
Im not even sure if I did it correctly. I think I may have only been pouring at about 1.5-2K instead of 2-2.5k. There was only heavy steam about 1/3 of the time (usually when the engine started to stumble and I gave it a little more juice)
But I took her on a highway run afterward, and it felt smoother, and idling at red lights seemed considerably smoother.
so, thanks. maybe ill try it again in another couple of weeks and see if I missed any
Old 04-17-2004, 04:09 PM   #38
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Default
Originally posted by amazinghl
I poured at least a qt of water in the engine. Tailpipe had NOTHING come out.
Originally posted by Applefool
I did this today with a spray bottle and didn't really notice much of any difference. I probably didn't use enough water. I used a full spray bottle, maybe 16 oz or so, and held the throttle open and just sprayed it in. it got slightly stumbly a couple times, but i just compensated a bit with the throttle. Not sure if it did any good. Didn't really notice anything making it out the tailpipe.
I did it today using 2 quarts of water after a long highway drive. The engine stumbled and jumped around a lot. Several times and again at the end I checked the tailpipe and the ground below. Nothing came out - no steam, no dark clouds, and nothing on the ground. Maybe amazinghl, Applefool, and I already had clean combustion chambers?
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-17-2004, 05:34 PM   #39
auxmike
auxmike's Avatar
Default
David,how did you introduce the water into the throttle body?
auxmike is offline
Old 04-17-2004, 05:37 PM   #40
thewretched
Default
even if it were clean, there would be at least a little steam.
its entirely possible that you just didn't pour the water fast enough. I know that I only got the steam clouds when I poured in very liberal amounts. Try it again in a few weeks, just be ready to nudge that throttle a bit more
Combustion Chamber jdw34 Vue Tech 6 07-23-2008 04:11 PM
water - Steam cleaning a 2.2L engine bgsneeze Ion General 5 12-02-2005 01:01 AM
combustion chamber cleaning daddio S-Series Tech 7 09-17-2004 08:52 PM
Piston/Combustion Cleaning? Applefool Miscellaneous Tech 2 09-30-2003 01:06 AM
water carbon cleaning EvilSL2 Miscellaneous Tech 4 05-16-2003 07:39 PM
