Closed Thread
Old 06-30-2004, 01:57 AM   #41
2000 SL 1.9
2000 SL 1.9 is on a distinguished road
Default
great post! thanks for sharing!
Add to 2000 SL 1.9's Reputation
Rate the quality of this post and help 2000 SL 1.9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000 SL 1.9 is offline
Old 06-30-2004, 01:00 PM   #42
leonards
leonards is on a distinguished road
Default
I
Wolfman,
have a '93 5-speed SL2 with DRL's but here in Canada the DRL's are the flashers, not the headlights. How will it affect the wiring?
Thanks,
Len
Add to leonards's Reputation
Rate the quality of this post and help leonards reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
leonards is offline
Old 06-30-2004, 04:09 PM   #43
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default
I'm looking at the same thing with a '94SL1. DRL's are the innermost set of lights, these are used as the turn sig's.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline
Old 07-25-2004, 07:39 PM   #44
zippy_LiL_sL1
zippy_LiL_sL1 is on a distinguished road
Default
this is what I see on my 2000 SL1 DRL Relay. Someone plz explain what all this means.
Add to zippy_LiL_sL1's Reputation
Rate the quality of this post and help zippy_LiL_sL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zippy_LiL_sL1 is offline
Old 07-27-2004, 09:40 PM   #45
wolfman
wolfman's Avatar
Default
30= POS power supply (to what you want to turn on) the 30 indicates it is a 30 amp relay. Can handle a current load up to 30 amps)
87 What will GET that power once the relay is tripped
87a What will GET that power when the relay is NOT tripped
86 1/2 of the trip circuit (can be EITHER POS or NEG)
85 The other 1/2 of the trip circuit can also be EITHER POS or NEG but MUST be the opposite polarity of the 86 terminal for the relay to be tripped.
Add to wolfman's Reputation
wolfman is offline
Old 08-14-2004, 01:00 AM   #46
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
ok, will this wurk if i disable my drl's??? or does this only kick in when i turn the lights on..by the way, i got same problem as the 2 up above, my drls are my brights..(well, not now, i switched the bulbs)
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 08-15-2004, 12:31 AM   #47
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
Default
it should work with disabled drls, but don't just remove the relay, short it out so the right hi beam works to.(i know there is a how-to around here somewhere,can't remember who posted it).
don't know what happens with drls enabled
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline
Old 08-15-2004, 04:06 PM   #48
the_skin_eater
1999 SL1
Default
ya, thats wut i was gonna do. thanx for the input, I will let ya know soon if it wurks or not.
Old 10-22-2004, 08:26 PM   #49
sdbarker
sdbarker is on a distinguished road
Default
So, what exactly is it going to take to get this mod to work on a 2001 SC2? I presently have the DRLs short-circuited.
-Scott
Add to sdbarker's Reputation
Rate the quality of this post and help sdbarker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdbarker is offline
Old 01-07-2005, 01:44 AM   #50
webxfx
webxfx is on a distinguished road
webxfx's Avatar
2004 VUE Red Line
Default Re: Hi/Low Beams at the Same Time
Originally Posted by L300Boy
I would like to announce the introduction of the Hi-Ho hi/lo modification from L300Boy inc. As you probably have decided, $20 is an outragous amount of money for this modification.
We offer several trim levels for under $7 DOLLARS!
Hi-Ho Classic:
This is our classic version of the ever popular Hi-Lo beam modification. Enough to modify several vehicles with black or grey interior. $6.98
http://www.tapemonster.com/master3.c...ta=Duct%20Tape
Hi-Ho Special:
The Hi-Ho Special is of the same quality of the Classic, but matches tan interiors. $4.25
Hi-Ho Sport:
The Hi-Ho Sport offers the quality of the Classic, but with the color Yellow. In addition to activating both high and low beams, it also gives your vehicle a sporty look and 5% performance increase*! $4.25
Are you for real?
Add to webxfx's Reputation
Rate the quality of this post and help webxfx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
webxfx is offline
Old 01-07-2005, 01:54 AM   #51
webxfx
webxfx's Avatar
2004 VUE Red Line
Default Re: Vue is wired different
Originally Posted by LB_BlueVue
Just did this mod on my '03 Vue. .
Took a little longer, as the Vue is apparently wired differently than other Saturns. The big difference is that, though the headlamps have their ground switched, the corner marker light is hot wire switched. This only changed the wiring slightly, but the change is quite important.
On my '03, here's the wire colors that matter:
Pink: High Beam ground (switched)
Blue: Low Beam ground (switched)
Brown: Marker HOT (switched)
NOTE: the turn signal lamp ALSO uses a brown wire. They look identical. Be sure to use the MARKER lamp, not turn signal. Also, it is a 18-20 guage wire, so the "add-a-tap" splices will not work properly (at least the ones I've seen only do 14-16 guage).
Don't forget to fuse the +12 Volt feed you'll need. Here's a link to my drawing: Diagram
I don't get why you are using the marker light in all this....
very nice picture....
webxfx is offline
Old 01-07-2005, 02:47 AM   #52
sierrap615
sierrap615's Avatar
if the low beams are always on with the high beams, DRL is a problem as they use the high beams. the way around this so the low beams are on with the highbeams and sidemarkers.
Old 04-02-2005, 12:19 PM   #53
joshjani
joshjani has a spectacular aura aboutjoshjani has a spectacular aura aboutjoshjani has a spectacular aura about
joshjani's Avatar
What size fuse do I out in the fuse holder? It's a 30 amp relay- do I put a 30 amp fuse in?
Add to joshjani's Reputation
Rate the quality of this post and help joshjani reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshjani is offline
Old 06-20-2005, 11:45 AM   #54
Vertigoomg
Vertigoomg is on a distinguished road
Vertigoomg's Avatar
1997 SC2
After 8-hours of ghetto-rigging this SOB, I've decided to just ghetto-rig it even further, because the whole thing is starting to PISS ME OFF.
1. The Fog/driving light kit wasn't at Wal-mart. Got a 4-wire adapter. NO RELAY. MORON! (I'm the moron, btw... nobody else...)
2. Got the relays and wiring. Didn't know how to connect them properly. F___.
3. Got some **** to connect them right. Got it rigged up and blew SOMETHING when I turned the engine over. F___
So now this is my plan: Run the power to my parking lamps, use the low-beams as the switch, highs as lamp, and ground it to chassis. Hook the power and ground wires to fog lights, so the fog lights will now by DRL's. Only problem with this is that I won't have DRL's with only parking lights on. Damn.
Correct me if I'm wrong.
Add to Vertigoomg's Reputation
Rate the quality of this post and help Vertigoomg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vertigoomg is offline
Old 08-31-2005, 07:51 PM   #55
micah_sl2
micah_sl2 is on a distinguished road
1993 SL2
Add to micah_sl2's Reputation
Rate the quality of this post and help micah_sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
micah_sl2 is offline
Old 08-31-2005, 11:37 PM   #56
sierrap615
sierrap615's Avatar
ow that hurt my eyes!!!
FYI in some areas having more then 4 lamps on is illegal (lows=2, highs=2, fog=2, total=6, be careful when you use them all together)
Closed Thread
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 11:06 AM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 04:10 PM
Hi/Lo Beams same time question joshjani S-Series Tech 1 04-02-2005 12:48 PM
Running Hi/Low beams at the same time Terrandus S-Series Mods 2 09-25-2002 09:16 AM
high/low beams run at same time?... LI 350 Miscellaneous Tech 2 08-09-2000 12:12 AM
